Hello there, I got a problem using Geforce 7600GS with Creative Soundblaster X-Fi Platinum. After I've installed the soundcard my display went into 4 color mode, and in 'Device Manager' the display adapter announced that "it cannot find free resources to work properly". I replaced the 7600GS card with my older card, Geforce 5200, and this card works fine with the soundcard.
Can you help me solve this problem so I can use the 7600GS card with the soundcard?
Since it sounds like a resource conflict, mabye you should use a different PCI-Slot for the x-fi. And make sure you disable all devices you don“t need in your bios (onboard sound for example!).
