Tom's Hardware Forums » Overclocking » CPUs » CPU Overclocking Reference/Post Your Results
Add a reply
 Word :   Username :
Bottom
Author
 Thread : CPU Overclocking Reference/Post Your Results
Run..Run.Hide.
Profile: old hand
More Information
Well figured it may be cool to have a list of results people are getting.
Please Post:
CPU Brand:
Model:
Manufacture: (venice,san diego..etc)
Cache:
How many cores:
vcore:
Memory to cpu Ratio:
FSB:
Cpu multiplyer:
FSB Multiplyer:
Speed:
Stock Speed:
Also post your CPU-z Validation if you have one (ill post mine when i get home)
CPU Brand:AMD
Model:Amd 64 4000+
Manufacture: San diego
Cache:1mb
How many cores:1
vcore:1.50v
Memory to cpu Ratio:1:1
FSB:240
Cpu multiplyer:12
FSB Multiplyer:1
Speed:2880mhz
Stock:2400mhz
Related Pr oduct
Profile: enthusiast
More Information
Here are my every day settings.. Cpu will go higher, to around 3300mhz before my memory craps out, I only do that for benching though.
Intel Core 2 Duo E6300 @ 3ghz, Memory 1:1(not like i have a choice)
Validate Link
Profile: Forum Veteran
More Information
Here's my Pentium D 840 overclocked to the limit with water cooling. The only way I could go further is with TEC or Phase-change and whatever crazy extreme cooling people use these days.
My highest overclock with this cpu is 4Ghz and anything higher causes instability.
http://img274.imageshack.us/img274/2997/4ghzoverclockeduh7.th.png
Cpu:
Pentium D 840 "Smithfield" = really hot son-of-a-b!tch
At 4Ghz cpu is at 1.55vcore (although CPU-Z reads the wrong voltage)
Temps at 35c-37c idle and 40c-42c on gaming. (the most demanding task for this gaming rig)
Also at 4Ghz the cpu is stable in all my gaming but unstable with Prime95 and 3DMark06. Runs no problem with BF2, Oblivion and FEAR.
Rams:
4x512Mb Corsair XMS2 Pro DDR2 533 3-3-3-8-12 2T
4Ghz settings at 3.9 volts at 400mhz 3-3-3-5-10 2T
FSB voltage +.03 volts.
At stock setting:
http://img236.imageshack.us/img236/529/32ghzat1to1ratio25ctempyp5.th.jpg
At 3.9Ghz setting: (3.92Ghz is my highest Prime95 stable overclock anything higher causes error but gaming wise could go 4Ghz no problem)
http://img236.imageshack.us/img236/931/39ghz30ccx0.th.jpg
Right now my cpu is at 3.6Ghz with 450mhz ram giving 1:1 ratio. The highest stable 1:1 ratio overclock with my cpu and rams.
Profile: Honorary Master of THGC
More Information
CPU Brand: AMD
Model: Opteron 175
Manufacture: Toledo
Cache: 2x1MB
How many cores: 2
vcore: 1.50 volts
Memory to cpu Ratio: 1:1
FSB: 240MHz
Cpu multiplyer: 11x
FSB Multiplyer: 5x
Speed: 2x 2.64GHz
Stock Speed: 2x 2.20GHz
Profile: addict
More Information
Edit: I clocked it 200 mhz higher to compete with assman's setup.
CPU Brand: Intel
Model: Core 2 Duo E6400
Manufacture: Allendale
Cache: 2Mb
How many cores: 2
vcore: 1.328
FSB: 400mhz
Cpu multiplyer: 8x
FSB Multiplyer: 4X
Speed: 3.2Ghz
Stock Speed: 2.13
Cpu-z validation
Run..Run.Hide.
Profile: old hand
More Information
Wow some of your overclocks are crazy cool :)
I think this would be a great sticky to show what cores/cpus have done and the voltage and manufacture (venice etc). It gives new'er people somthing to shoot for.
I know there are posts all the time about "what can x do?" This way its something people can look at. Maybe ill make a table with several cpu's on it with voltages etc if enough people post there results.
My cpu-z validation is in the sig.
Run..Run.Hide.
Profile: old hand
More Information
Quote :
Cpu:
Rams:
At stock setting:
I like yours its way nice 800mhz is pretty impressive.
Profile: addict
More Information
I got 870 mhz. Right now I'm in the process of trying to go to 4 ghz. 40% there.
Edit: I cant get to 3.5 ghz unless I crank voltages up to 1.46. Im not going to go that high. Thats 0.11v over the max. My temps were still pretty low when running prime 95. It got to 58 C according to core temp. Gigabyte monitoring software said 54 C.
Run..Run.Hide.
Profile: old hand
More Information
Yeah thats crazy too, But 4ghz i dunno i dont think its possible on air.
Then again your voltage is only 1.23v so i dont know alot about the c2d but for a amd64 thats low.
Profile: addict
More Information
CPU Brand: AMD 64 X2
Model: 4800+
Core: Toledo
Manufacture: AMD
Cache: 2mb L2
How many cores: 2
vcore: 1.35
Memory to cpu Ratio: mem is set at 333mhz
FSB: 233
Cpu multiplyer: 12
FSB Multiplyer: 4
Speed: 2.8ghz
Stock Speed: 2.4ghz
Profile: old hand
More Information
CPU : Intel Core 2 Duo E6300 (*1)
CPU Arch : 2 Cores
CPU Cache : 2048 KB
Core : Allendale (65 nm) / Revision : B2
Freq : 2894.34 MHz (413.48 * 7)
MB Model : ASUS P5B-Deluxe
NB : Intel P965/G965 rev C1
SB : Intel 82801HB (ICH8) rev 02
RAM Size : 2048 MB
RAM Freq : 413.5 MHz
RAM Type : DDR2-SDRAM Dual Channel
RAM Ratio : 1:1
RAM Timings : 4-4-4-12
Slot 1 : 1024MB (PC2-5300)
Slot 1 Manufacturer : PDP Systems
Slot 2 : 1024MB (PC2-5300)
Slot 2 Manufacturer : PDP Systems
More Information
Thanks, but it's only 25% overclock and maybe impressive on an 840 scale. Meh! :)
*Lesbian Lover Club* Founder
Profile: Faithful Poster
More Information
CPU Brand: Intel
Model: e6400
Cache: 2mb
How many cores: 2
vcore: 1.385
FSB: 400
Cpu multiplyer: 8
Speed: 3.20
http://img216.imageshack.us/img216/1639/cpu3199wz6.png
Profile: stranger
More Information
CPU Brand: Intel
Model: X6800
vcore: 1.65
FSB: 420
Speed: 4.2
Stock Speed: 2.93
http://www.hqraid.com/avhost/oc1.png
http://www.hqraid.com/avhost/oc2.png
Run..Run.Hide.
Profile: old hand
More Information
Quote :
Yeah for the 840 is kewl :)
Run..Run.Hide.
Profile: old hand
More Information
Wow 4.2ghz is tight, can the e6400 reach that?
More Information
Quote :
With water cooling the E6400 can attain 3.3Ghz range, based on reviews I have read. With a phase change cooler it might be able to reach 4.2Ghz. Core 2 is just one amazing overclocker, I can't wait to get my hands on them E6600 on my next upgrade. :)
More Information
Quote :
I'm sure you can go higher than 3.3 on water, i mean mine is running 3.2 on air and temps are 43-46C/49-51C idle/load
More Information
I'm sure you can, why not get a water cooling? Push that thing to the max. How far can you push that cpu on air cooling anyways?
Profile: nimble knuckle
More Information
