I cant put my sapphire ATI x800gto agp, work right, tried any drivers one by one , i did update to board bios also without luck to put it working. The problem its it laggs my system cpu and all games crash, even the computer crash also, i have a nVidia VGA and it works well.
nForce3 is the problem??? I dont know.
Help me.
Thanks.
system info
Hard:
MSI K8N NEO nForce3 MS-7030 V1.0
AMD Athlon 64 3000+
Kingston 512MB 400MHz
Sapphire X800GTO AGP
Seagate Barracuda ST3120026AS 120GB 7200,7
Soft:
BIOS: Phoenix - Award WorkstationBIOS W7030NMS V2.1 111005 09:36:51 OS:Microsoft Windows XP Version: 5.1.2600 Service Pack Drivers:MSI nForce3 Drivers 5.03
Sounds to me like you need to disable your onboard video if you have one, if you do go into your mainboard bios and disable your onboard video, and make sure that it's also set to use AGP first.
Then you might want to make sure nothing is Over Clocked on your system, CPU, Vid Card, Memory that could be causing the lag and crashes.
and if all else fails backup your important stuff and do clean install of WinXP.
I have that same card you have great card once you get it working
BTW
Making sure you uninstall old drivers are very important, you say you have a nVidia card not sure if it's onboard or not, as that can cause some issues, uninstall all video drivers and make sure winXP uses standard VGA adpter before you install new drivers, and make sure you have Anti-Virus programs off durring install as that can cause some problems as well.
Thanks man... I know is a great VGA, but i dont have onboard video.
Particularly, when i can put the VGA, in device manager, they appear two VGA's installed without other one installed, and after the new installation the operative system... Is right???
If you are seeing 2 VGA adapters in device manager, the only thing I can think of is that the drivers for either card didn't get uninstalled all the way, and I believe you can't removed the second without first putting in the card that was taken out.
So uninstall both cards and drivers, pop back in the other one install it and then uninstall it, that should remove the double VGA in device manager.
if you take out old card without uninstalling it and pop in new card and install drivers for it, that is going to give you major problems.
and you might want to get a regiersty cleaner, ccleaner comes to mind and run that before you install drivers again, but make sure your system is display driver free before install.
