Bought a Raptor 74G from Newegg... I couldn't resist the hype... I installed XP on it not once, not twice, but three times and it just doesn't reboot after I begin installing all my programs!? (a routine I've done MANY times w/out problems) Installation of XP was faster, not as fast as others made it seem... The little blue bar (when loading windows) goes by 4-5 times... while my sataII drive was 3.5... (others post it only passes once)->Which mine did the first few boots... Then:
Windows could not start because the following file is missing or corrupt:
\Windows\System32\config\system
It did this each time I installed different programs so it wasn't any certain one... plus after the 3rd install of XP some programs wouldn't even load!?
ANYONE?? HELP!! Should I RMA it? Refund? Will a good raptor be worth it? I ran it through a check/scan disk and it came up fine? SMART shows spin up time value as 2300 or something!? HHEEEEEEEELLLPPPPP!!!!
