Thank you for your time. I recently finished installing a Koolance CPU-300-V10 to a IntelD805 processor on an asus p5n32-sli motherboard. (basic water cooling setup) I have succeeded in getting power to everything, and succesfully ran a water test before installing all the components. Now my problem is, when I turn the system on, the system heat alarms keep going off as the temperature continues to rise. After about 5 minutes, the temp will rise from 23degrees celsius to 32degrees celsius. Is this normal? Could the temp gauge be acting up? As of now I have the sensor for the CPU next to the CPU, but not physically touching it. The other 2 sensors are untouched. I'm afraid to run the system for more than 5 minutes, so is this heat range normal? Or what could be causing the CPU to heat up so fast as I have the cooling block installed the same as a friend of mine, who has the same set up. Any thoughts are greatly appreciated. Thanks!
