Tom's Hardware > Forum > Computer Peripherals > Scanners > Problem with Minolta Scan Elite 5400 using Vuescan
Forum Computer Peripherals : Scanners - Problem with Minolta Scan Elite 5400 using Vuescan
Archived from groups: alt.comp.periphs.scanner (More info?)
I have just paid for Vuescan to use with the 5400 scanner. I have just tried
to scan some mounted slides (using the mounted slide holder that came with
the scanner) and they have all scanned out of focus. If I scan unmounted
film using the unmounted film strip holder (supplied with the scanner) the
same images are in focus. If I use the original Minolta software the images
are in focus using both holders. I can only assume that I have the Vuescan
software set incorrectly. Two questions:-
1. Will Vuescan work with the mounted slide holder.
2. If so, what settings should I use in the Vuescan software
Sorry if these are stupid questions but I cannot find the answer in the
manual, either that or I am just blind.
Regards Colin Ackerman
Check out my Web site at www.aboveusthewaves.com
Available soon my Dive Trip report to St Vincent - September 2004
Sponsored Links
There are 1294 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 torbee won the Freshman badge
  • 01:00 dba won the Uniformed badge
  • 01:00 LoveMyslf won the Uniformed badge
  • 01:00 survdirt won the Uniformed badge
  • 01:00 vgigolo won the Uniformed badge
  • 01:00 alex3003 won the Uniformed badge
  • 01:00 dindarloo won the Uniformed badge
  • 01:00 Akash Nain won the Uniformed badge
  • 01:00 greeneman510 won the Uniformed badge
  • 16:28 bilbat won the Motherboards badge
