Hi, can anyone shed some light on what's going on?
Intel Core2 E6600 on a Gigabyte GA-965P-DS3 (Bios F7), entered BIOS and changed multiplier to 8 and fsb to 400 (no voltage adjustments).
Booted into WinXP and using these apps it shows different temps and clocks.
Reading up, I can see the temps may be down to the different sensors used.
But what about the clockspeed, I assume Im not running 3.6GHZ!!
I cant be running a 450fsb!
Any advice would be great, many thanks.
coretemp 0.93
cpuid 1.36
easytune5 build 2006.08.25
speedfan 4.31
I posted this in CPU's earlier, because software readings is not specifically overclocking. But when I thought about it, I figured it was more suited in this forum.
Since then, I've noticed something very weird. Prime95 failed when running two seesions, so I went back to BIOS and changed to 9x320 instead of 8x400
Now all the apps have the correct clock speed reported, and prime95 is running well in dual. So was I running 450!!!! or was it just crappy software which assumed a 9x multiplyer and hence the 3.6GHZ.
Thanks again + apology for repost, hopefully more correct area.
coretemp 0.93
cpuid 1.36
speedfan 4.31
