Tom's Hardware > Forum > Wireless Networking > Range & connectivity > Limited or No wireless connection
Archived from groups: (More info?)
I have a network set up in my house. Three computers connect via wireless.
All three have Very good to excellent signal strength, all three can connect
using current setup.
Here's the problem: all three periodically drop off the network with the
limited or no connection error. From time to time they will just as suddenly
re-connect, and work fine.
I know it has to do with the router assigning a DHCP address, but what is
causing it NOT to assign said address?
The router is a brand new Linksys WRT54G, two of the three computers have
Linksys cards, one has a D-link card.
All computers running XP-SP2 using Windows networking software.
Les R
All Outgoing Mail screened with NAV
Age is a high price to pay for maturity.
Sponsored Links
How do you know that? That sounds quite unlikely because the router
will only offer an address in response to a client requesting it and
it's unlikely that they all do so at the same time. If you want to kill
your theory, then assign a longer lease and I suspect you will still
suffer the same problem.
What is more likely happening is some interference that is causing all
clients to lose their RF connection, then what happens is that they re-
associate and then you see a request for an IP address which is normal.
David.
Reply to Anonymous
On Sun, 4 Sep 2005 08:43:57 -0700, "Feverish"
Periodically? Is it at regular intervals, which is the definition of
periodic? Or is it at random intervals for random lengths of time?
It sounds to me like an RF interference problem. Possibly another
wireless system, microwave oven, or other source of 2.4GHz trash. If
you could provide a better description of the timing, I can try to
guess the source by the pattern.
Nope. That's not the problem. If you don't have connectivity, DHCP
renewal will fail. Unless you turn on all three computers at the same
time, there's no way that all three leases will require renewal at the
same time. Also, the default lease time is one day so you should not
be experiencing problems "periodically" if caused by DHCP issues.
Methinks not.
Models of Linksys cards and D-Link card?
Try changing the RF channel in the WRT54G in case it's interference.
You're choices are 1, 6, and 11.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Reply to Anonymous
- 0 +
"Feverish" <feverish@NOcox.SPAM.net> wrote in message
news:uCESe.7831$ct5.7306@fed1read04...
>connect using current setup.
> suddenly re-connect, and work fine.
> Les R
I had a wrt54g (new) dropping wireless clients frequently and irregularily.
I reinstalled the firmware and did a hard reset of the router. After that
all was well.
Ian
Reply to Ian
Because a little box pops up and says I am unable to acquire a DHCP
address??
Les R
"David Taylor" <djtaylor@bigfoot.com> wrote in message
news:MPG.1d8529d0e04a1429989dfe@news.cable.ntlworld.com...
> David.
Reply to Anonymous
Irregular intervals.
No 2.4 phones.
There are other networks that occasionally show up, all weak signals.
Channel is NOT set to default, I believe I have it set at 6.
Linksys cards are WMP54G, I don't remember the D-link card, (and at the
moment don't want to open the case.) I don't think it is the cards since it
affects both brands the same way. I don't even think it is the router per
se, since this happened with my old router as well. (Fried a circuit on the
old one somehow, one day it just didn't light up) Router plugged into Surge
protector, as is other items, only router went bad.
Les R
"Jeff Liebermann" <jeffl@comix.santa-cruz.ca.us> wrote in message
news:haamh11u2r5minqbl5b5b82hv7ndchblhf@4ax.com...
>>connect
>>suddenly
> Methinks not.
Reply to Anonymous
On Sun, 4 Sep 2005 17:40:13 -0700, "Feverish"
I asked for more descriptive, not less. Approximate interval and
duration in minutes. Does it coincide with meal times? Coincide
with 15 minute commercial breaks? Are you near a cafeteria full of
microwave ovens? Any TIVO boxes with wireless? Any 2.4GHz security
cameras? Any 2.4Ghz cordless mice?
>No 2.4 phones.
It doesn't have to be yours. I could be your neighbors. Is your
wireless router perhaps sitting in a window with a good view of the
neighborhood?
90% of the wireless access points are delivered configured for channel
6. Please try channel 1 or 11. If in UK, try 14.
OK. Good card. Comes in 4 different models. Check the power save
settings on both cards. Some cards don't recover very gracefully when
the computah goes into hibrination, sleep mode, power save, or
wireless card power save (all these are different).
Assumption, the mother of all screwups.
Good clue. That's another reason why I suspect RF interference. If
both the old and new routers were mostly working, then interference
will affect them both equally.
I spend the better part of a day troubleshooting an erratic disconnect
problem. Eventually, I discovered that the wireless router was
rebooting. A little investigation uncovered a defective power strip
that was very intermittant. Check your power please.
>address??
Which program is generating that error message? That's not the common
error message delivered by Windoze XP SP2 Wireless Zero Config.
However, that's just a curiousity item. There are only 2 things I
know that can prematurely require a premature DHCP renewal without
rebooting the computer. Interference won't do it.
1. The router reboots.
2. The wireless client radio or computah goes to sleep.
The WRT54G has the uptime on the status page. You can see if there
have been any uncheduled reboots by monitoring the uptime.
Temporarily disable *ALL* the power save features in the wireless
client computah and see if that magically fixes the problem.
Reply to Anonymous
Off line about 36 hours now, straight. Doesn't coincide with mealtimes,
nearest microwave is downstairs in Kitchen, but doesn't seem to be related
to MW usage. Commercials are boring, but not part of the problem. No
cafeteria, no TIVO, no cameras, all phones are 5.4 Ghz. I do have a wireless
mouse: Logitech MX700 now replaced with MX1000.
Can't answer re:Neighbors, only that we've never been able to eavesdrop on
their conversations, one wireless network, occasionally picked up could be
neighbor. Signal weak, and encrypted (not that means much in this setting
that I know of.)
Router is on streetside, but I've no choice in this matter.
Channel is set to 9
Power save on all cards turned off
How do I determine the "uptime" I can't find a setting/log for this?
As far as I can tell neither router nor modem are spontaneously rebooting.
Error message reads (paraphrasing) Windows could not repair your internet
connection because it could not complete the following action. Windows could
not renew the IP address. Please contact your system administrator(that me,
and I haven't kept anyone off as far as I can tell.)
Les R
news:717nh1l4696r0nc1cklv9o3f7u177g178m@4ax.com...
>>No 2.4 phones.
> neighborhood?
>0
>>Surge
>>address??
Reply to Anonymous
had a similar problem, was due to other wireless access points nearby
sharing same channel, fixed by changing the channel via the admin setup
page, e.g. at 192.168.1.1 or 2.1 etc
apparently there is some kind of bug related to the protocol grabbing
one of the undesired access points instead of your preferred access
point
there seem to be numerous network bugs in XP connectivity software in
general as well
Reply to Anonymous
On Sun, 4 Sep 2005 22:01:34 -0700, "Feverish"
I have a feeling I'm reading this wrong. Does this mean that it fails
to connect every time you've tried it over the last 36 hours? Or does
it mean that you've been experiencing random connection failures over
the last 36 hours with occasionally successful connections?
Ok, that eliminates most local sources of interference. Please note
that some models of 5.2GHz cordless phones use 2.4GHz on one
direction. I vaguely recall that it's the handsets that transmit
2.4Ghz and receive on 5.2GHz but may have it backwards. Also, some
cordless phone bases transmit continuously, even when the handset is
in the on hook position. Pull the plug on the base and see if that's
the problem.
I couldn't determine what frequency it's running on, but it probably
is not 2.4Ghz.
>that I know of.)
If they're not broadcasting their SSID, you won't see any nearby wi-fi
access points.
>Channel is set to 9
Channel 9 is roughly half way between channel 6 and 11. The wi-fi
signal is approximately 5 channels (25MHz) wide. If there are nearby
access points running on channels 6 or 11, you will get interference
from both. I suggest you stay with the recommended 1, 6, and 11 or 14
in the UK.
What about power save, hibernate, and standby on the computer?
I'm using a WRT54G but with Sveasoft Alchemy firmware. My "status"
page shows the uptime. However, I guess you're using the official
Linksys firmware, which might not have this feature.
Rebooting the modem would not cause a premature DHCP renewal. Only
the router can sometimes (not always) do that. Usually, it's the
client that asks for a new DHCP address. The reason I'm emphasizing
the possibility is that your symptoms of not getting a new DHCP
address after a connection drop do not make sense unless either the
client initiates the DHCP request, or the server (router) reboots.
That's the message you get when you select "Repair" from the right
click menu on the Windoze XP SP2 Wireless Zero Config icon. Is that
what you're doing? Repair does *NOT* mean re-connect. The correct
procedure is to "Show Available Networks", select your wireless SSID,
and hit "connect". Both Connect and Repair will attempt to renew the
DHCP address which apparently is failing for some reason.
What else are you doing that you're not disclosing? From your
descriptions, I'm having difficulties guessing what you're doing, and
what's happening.
>(that me,
Could you explain what you mean by "drop off the network" as in your
original question? If it means loss of internet connectivity, are you
*SURE* that it's not a problem at the ISP, and that you're trying to
fix it with the WZX Repair feature? More specifically, does the
"limited or no connection error" happen *AFTER* you do something with
Windoze?
"Here's the problem: all three periodically drop off the
network with the limited or no connection error. From time
to time they will just as suddenly re-connect, and work fine."
Let's pretend that there's nothing wrong with the wireless and that my
guess as to decoding the symptoms and actions are correct. Next time
you have a good connection followed by all computers "dropping off the
network", try this experiment. Do NOT do the Repair thing:
Start -> Run -> cmd <enter>
ipconfig
Does it show a proper IP address? If yes, you don't need a new one.
If 169.254.xxx.xxx, then something caused the clients to demand a new
IP address. This would be rather weird and uncommon. My guess is
still a power save timeout at the client.
Next, see if you can talk to the router with:
ping 192.168.1.1
If you get proper responses, your wireless connection is intact and
functional.
Next try to ping the other computers on your LAN. They should be
192.168.1.100 and up. Get the IP addresses with ipconfig in advance
so you're ready to try this. If you have a firewall in place, it may
prevent ping from working.
Next, try to ping something on the internet. The obvious starting
place would be the gateway IP at your ISP to see if the cable modem or
Cox is down. However, that might change periodically. Grab the IP
address of the gateway from the WRT54G status page. Also ping some
common web sites such as www.yahoo.com. If that doesn't work, try
pinging them by IP address (you'll have to get the IP address when
it's working and write it down in advance). If that fails, go yell at
Cox support.
The idea is to isolate what part of your connection puzzle is failing.
Reply to Anonymous
> address??
Red herring.
Reply to Anonymous
I just had that same exact error message, using free WiFi while staying at
the LaQuinta in Sacramento. It was a router issue. Access was spotty, come
and go, then nothing. Disconnecting and trying to "repair" wouldnt fix it.
When it was connected, it had good signal strength.
I was wondering if there was a set number of conection limit hit, and it
would drop.
> Les R
Reply to Anonymous
Off line means No connection via wireless only. I cant hit the Connect
button ( unless I disconnect first) since I'm connected but don't have a
DHCP address. I have to repair or disconnect/ reconnect (which is what
repair seems to do anyway,) One computer was online for about 15 minutes
after a "repair" but then dropped off. Another computer was offline then
suddenly was online for a while before dropping off. No problem with ISP
since wired computers online 24/7.
I do see neighbors wireless connections("Phoenix-house", "Dorsey" but no
bars and we can't connect via their routers.)
Pinged two of the wireless computers, one timed out and no data received,
one sent back data packet, but is still "offline."
Will change to Channel 14 (but I'm US)
Les R
news:b9ooh1hjqkfq2lbsg8vvqt3e5bljj1bkq2@4ax.com...
> the problem.
> is not 2.4Ghz.
>>that I know of.)
> access points.
>>Channel is set to 9
> in the UK.
>>could
> what's happening.
>>(that me,
> Windoze?
> ipconfig
> ping 192.168.1.1
> functional.
> Cox support.
Reply to Anonymous
Oops no Channel 14, trying channel 11
Les R
news:d08Te.11541$ct5.6373@fed1read04...
> Les R
>>>related
>> the problem.
>> is not 2.4Ghz.
>>>on
>>>be
>>>that I know of.)
>> access points.
>>>Channel is set to 9
>> in the UK.
>>>rebooting.
>>>could
>> what's happening.
>>>(that me,
>> Windoze?
>> ipconfig
>> ping 192.168.1.1
>> functional.
>> Cox support.
Reply to Anonymous
There are 617 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
