Tom's Hardware > Forum > Overclocking > AMD > help a newb: processor agp and ram overclock, fan issues, e
Forum Overclocking : AMD - help a newb: processor agp and ram overclock, fan issues, e
a64 3000+, ga-k8nsc-939, 2x512 legend 3200 T6464D47-BU1LDC9M, agp-radeon 9250
hi ive never ocd my old pc before but its starting to have trouble running the latest softwarez etc so i thought id give it ago.
okay so i got the processor running stable at about 2.52 ghz with a little bit more juice and multiplier settings
the thing i understand the least is the mem. im looking at A64Tweaker.exe
my memory is LEGEND pc3200 DDR400 btw (running at 209mhz)
the cas latency: 2.25,
ras-to-cas: 3
ras to ras: 3
min ras active : 7
i got those numbers from looking at other peoples posts on this forum and they seem to work fine.
there are a lot more ram timing settings available - r there any others i should look at? getting my ram any faster than 210 mhz seems to make it crash - is this normal for this type of memory? should i try giving it more power?
i have given the CPU +.075 (1.475) and the ht link +0.1, is that okay?
thanks very much! :D
Sponsored Links
the exact model of the memory is T6464D47-BU1LDC9M. i downloaded the specifications pdf from legends website however it doesnt seem to mention any timing values, only electrical stuff.
i got the program prime95 and tried all three torture tests which failed instantly so i guess this is indicating both the processor and ram are set to fast...is that right?
also, i have clocked up the agp port (running a radeon 9250) to over 100mhz without any problems, is this a good idea/normal? granted, the only graphical application i use at all is milkdrop and media player. but i thought it might be worth bumping it up for better performance in milkdrop.
one final question, i have got the program speedfan. my 'core' temp is only 30 degrees celcius under stress (an i live in a hot climate), however the temperature of my ide hdd is 49 and has a warning (i didnt even know my harddrive had a monitor), is something going wrong?
also, speedfan says i have 3 fans and 'Fan2' is off. i can only see 2 fans visably when i open the box; one on the processor and one on the case. is speedfan making a mistake or do i really have another one that is off (maybe thats why the hdd is overheating)??
Reply to meatwalker
There are 865 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
