Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Help me make my final water cooling decision!
Forum Overclocking : Cooler and Heatsinks - Help me make my final water cooling decision!
Which kit should I go with
Warning, if you click on "see results", you won't be able to vote
Ok, I have been deliberating for many weeks on how I want to water cool my PC. I am only going to be cooling CPU (D805 @ 4.0Ghz+) for now.
Here are my choices:
1) Swiftech H20-220 Apex Ultra---$240
2) Swiftech H20-120 ---$150
3) DIY kit with the Apogee block used in both kits above, Danger Den MAG II LE pump, Swiftech Dual 120mm Rad, and using a T-Line and Fill-Port.---$190
What I'm asking is what do you guys all think I should do. I would like to keep it internal (Option 2) but it might not even be possible to fit it in my Antec SuperLanboy case.
Does the performance addition of the dual rad kits (1 & 3) outweigh the price increase? I was hoping to spend under $200 but if the Apex kit is going to be better, I can probably swing the extra $40/90.
How much performance increase can I expect going from a single 120mm rad inside my case (2 fans in push/pull) to a dual rad outside my case with 2 fans (push/push or pull/pull?)
Has anyone used UV dye inside UV tubing? For example, blue UV tubing with red UV dye, I think it may look coool with a red/purple core and blue outside.
Sponsored Links
Guess I'm not understanding everything. None of the kits have a GPU block and I won't be using two rads, the difference only being a single 120mm rad or a single (dual fan) 240mm rad.
Is the DD Mag II LE not a good pump? I have only heard/read good things about it, and told it would run my loop just fine.
Reply to tool_462
Can you show me where I can build the kit #3 for $130? Cheapest I can find is about 190 shipped, not sure what I'm missing...
Reply to tool_462
go #3, except change the rad to a Black Ice Xtreme II Radiator http://www.dangerdenstore.com/prod [...] =85&page=1
get tygon
and go to this guide http://www.xtremesystems.org/forum [...] hp?t=54331
this has a WEALTH of information. Look around in the "liquid cooling" section, and youll find a load there to. This website proabably saved my 4 months of researching
Reply to mcain591
Been browsing eBay very much in the last couple weeks, haven't ran across but a couple Apogee blocks that sold for more than websites charge and havent seen a single Storm. A few TDX's but they are all buy-it-now for overpriced. I will continue lookin though.
Thanks for the tip on the guide, very nice!
Reply to tool_462
anytime wusy
btw, we should create a specific "water cooling" and related section, and throw the guide that is already in "cooler and heatsinks" along with some other things in there as well.
Reply to mcain591
I have a week old water cooling set that I am reselling.
You can see what it contains here: Water Cooling Set
If anyone is interested just send me a message.
Reply to floge03
The Swiftech Storm cpu water block and MCP655 pump is a very good performance components. I know that for sure since I currently use them with my DIY cooling loop.
Reply to chuckshissle
Is the A64 version the same block inside? That doesn't seem like it would be a tough mod. My grandfather has a laser cutter that could easily cut a piece of 1/8" steel or something and drill the holes in it.
Reply to tool_462
There are 1218 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
