I had to take apart my system to switch the inlet and outlet on my storm cpu block as well as drain that mct 5 crap out. While draining it I spilled a little bit of it on my motherboard and video cards. (the power was disconnected while I was doing this) I put rubbing alcohol on the parts of the computer that the mct 5 had tuched with a qtip and let it dry for about an hour.
I then plugged the system in and when I hit the power button nothing happens...
The green light is on that is on the motherboard and the fan is running in the power supply but that is it. I am not sure what happened or what to do. Any suggestions are greatly appriciated. Thank you.
