Tom's Hardware > Forum > CPU & Components > Sound Cards > cheapest sound card
ok i'm looking to upgrade my onboard sound and i want to get the cheapest sound card that is better than my onboard. aparently some cards can decode eac 3 and 4, i dont know much about this stuff but i have 5.1 surround sound(z640) and i want everything to sound just a bit better.
Sponsored Links
hi
i do't know which one is the cheapest sound card,
but almost every card will sound better than your onboardcard.
better get a card that can be connected to 5.1speakers.
Reply to bacis
Do you have good speakers? Bad speakers will make any soundcard sound bad. Make sure you have a good set of speakers first.
Reply to sturm
I gots the Creative Soundblaster Audigy 2 SE, I think it's called, for $28 Canadian (about $25US). It's nothing fancy but the sound is way better than my onboard sound, which had a booming bass on the default settings that would rattle my dishes ( I have 12" woofers). The Audigy had nice clear balanced sound right out of the box. I primarily bought the soundcard to use it's coaxial digital output as I was getting the dreaded speaker hummm using the normal onboard connections. Not sure about the EAC stuff. Audiophiles will poopoo this card and say you need the $80 XiFi or whatever, but it works for me!~
Reply to Invader
Quote :
Consider:
http://www.newegg.com/Product/Prod [...] 6829102010
or
http://www.newegg.com/Product/Prod [...] 6829102002
or
http://www.newegg.com/Product/Prod [...] 6829102011
Reply to halcyon
i second the 3rd one, but if you really want cheap check this one out!
http://www.newegg.com/Product/Product.asp?Item=N82E16829180001
cheapest on the 'egg, now of its going to be better than our onboard sound or not...
Reply to apt403
There are 1236 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
