CPU
AMD Athlon 64 X2 4600+
- Core Speed 2415
- Multiplier x 12.0
- Bus Speed 201.3
- HT Link 1006.3
Motherboard
M2n32-SLI Deluxe ACPI Bios Revision 0706
Memory
Corsair CM2X1024-5400C4 (PC2-5300)
Frequency - 301.9 MHz
FSBRAM - CPU/8
BIOS is set to DDR 667 as well to hopefully force the right MHz.
And now to my problem. Should the frequency not be 333 MHz? Instead of 300? I imagine it's because of the FSBRAM divider however I can't seem to find the setting for it in BIOS to save my life.
As for the rest of the info listed I understand it to a point but I've been out of the computer scene for over 2years and dealing with quite a bit of new tech. So HT, DDR2, and a few of the others are new to me and the info makes sense but without a reference it's hard to say that xxx number is fast if I don't have a reference to that tech. Been doing as much catching up as possible in such a short time but so far searching the forum I've been unable to come up with a solution to this one.
- Core Speed 2415
- Multiplier x 12.0
- Bus Speed 201.3
- HT Link 1006.3
Motherboard
Memory
FSBRAM - CPU/8
