Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > help: wireless router laptop card problem
Archived from groups: (More info?)
hi all
i have a belkin 125mbps wireless router setup. it works with bot pcs fine,
but wont work with my laptop.
i have a 54g pcmcia card in the laptop and the belkin software. the network
is found no probs but it wont log on. i have set and un set the security,
with no luck.
ive installed new / updated drivers and software and uninstalled it and
reinstalled it again.
anyone know a quick fix.
any more info i can give please shout.
thanks
scaffman
Sponsored Links
Hi
"If" the card you have is a Linksys WPC54g and your laptop has a Texas
instrument cardbus controller you will beed to download different drivers
from the website ftp://ftp.linksys.com/beta/wpc54g_beta_driver.zip .
Cheers
Eddie
"SCAFFMAN" <SCAFFMAN2003-N-O-S-P-A-M@TISCALI.CO.UK> wrote in message
news:8lXZe.1356$iW5.1348@fe3.news.blueyonder.co.uk...
> hi all
> network is found no probs but it wont log on. i have set and un set the
> security, with no luck.
> thanks
> scaffman
Reply to Anonymous
card is a belkin 54g same make as the router,
all worked fine till the last router lost range over night.
hence the replacement.
thanks
s
"Eddie Rogers" <eddie@notmyemailadress.com> wrote in message
news:1127764724.2d81c18c96f24b2a253b593cd037ff7d@teranews...
> Hi
> Cheers
> Eddie
>> hi all
>> fine, but wont work with my laptop.
>> thanks
>> scaffman
Reply to Anonymous
- 0 +
Hi
I have had a lot of problems recently trying to setup a wifi network with a
Belkin 54g adsl router.
The problem was that I could only get one pc at a time to connect - I tried
absolutely everything, however in the end I did a factory reset on the
router and re set it up again since then it has been working ok.
If all else fails try the factory reset.
Good luck
Eddie
news:f_3_e.3183$iW5.1784@fe3.news.blueyonder.co.uk...
> thanks
> s
>> Hi
>> Cheers
>> Eddie
>>> hi all
>>> thanks
>>> scaffman
Reply to eddie
- 0 +
Another thought - do you have Norton Internet Security? - if so you may need
to set the firewall up to recognise the wifi card until then the firewall
may block it intermittently.
And er that's about it no doubt I'll think of something else as soon as I
have posted this!!
Cheers
Eddie
"Eddie" <eddie@notmyemailadress.com> wrote in message
news:1127853364.3dca89079d4336e96b230fbb42b36963@teranews...
> Hi
> a Belkin 54g adsl router.
> tried absolutely everything, however in the end I did a factory reset on
> the router and re set it up again since then it has been working ok.
> Good luck
> Eddie
>> thanks
>> s
>>> Hi
>>> drivers from the website
>>> Cheers
>>> Eddie
>>>> hi all
>>>> thanks
>>>> scaffman
Reply to eddie
Thanks for the replies
but no good, dont use norton.
thing is it was all working perfectly before.
s
Reply to Anonymous
There are 1254 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
