I need some urgent advice now cause right now im just finished putting up my home-build comp but for some reason it doesn't boot. When i pressed power button, nothing happened!!! but if i pressed the reset button, the cpu heatsink fan started to spin!? I don't know what did i miss when i assembled them. I checked the 24 pins power cable, it fitted in but it just didn't come all the way donw or latched in, the gap is about 1-2mm so can this be the culprit?
Thanks in advanced!
Thanks in advanced!
