Heres my situation. I just bought a new computer with the following specs. It cost me about $750.
3800+ X2
1 GB DDR2
250 GB hard drive
19 inch widescreen LCD
Integrated 6150LE graphics (For now)
300W power supply
I want to buy a new graphics card, something along the lines of the X1950pro. I was going to buy the X1900GT, but then the pro came out which seems to be slightly better. My problem is that i just spent $750 on a new computer system, and I really don't want to spend that much more. Originally i thought i was just going to have to buy the graphics card for a little less than $200, but now i realize that there is a good chance i'll have to buy a new PSU as well.
My question is: What would happen if the graphics card tries to draw more power than my system can supply? I ask this because according to this review http://techreport.com/reviews/2006q3/radeon-x1900gt/index.x?pg=9 and a few other reviews, a system with the x1900GT will never call for more than 300W of power even under load.
Do you think i can get by with a 300W power supply even though the card "says" it requires 400W?
If you don't think so, what would the down sides be to buying a cheap 430W power supply like this? http://www.newegg.com/Product/Product.asp?Item=N82E16817171007
Thanks for help in advance.
3800+ X2
1 GB DDR2
250 GB hard drive
300W power supply
