hello i plan on getting a watercooled system soon i was wonderign what the best route would be, should i make a custom one and buy each part seperatley or would i be better off buying the thermaltake armor lcs case, which has built in watercoolign then jsut add a vga block? either way i want to get the armor case i have around $500 to spend on case/ watercooling system ive never hooked up a watercoolign system before and was just wodnering which way would be better to go. Please help if you can.
