Hi, I was wondering if anyone out there could help me out with a super loud and annoying chipset fan on the Northbridge of the MSI K8N Neo4-F (nForce4) motherboard. Im not sure if the fan is dying but it is so very loud, it stands out in the room over anything else.
I was looking around on newegg for a replacement and I came acorss this: http://www.newegg.com/Product/Product.asp?Item=N82E16835118214
I am a little worried about this since the PCIe slot is very close to the chipset. Would this zalman fit? Would I have to chop off several fins to make it fit? Heck, I dont even know if the zalman is compatible..
Any help would be greatly appreciated
