Right now I have a swiftech 360 radiator, resevoir, 655 pump, storm cpu block, (2) dangerden maze4 gpu blocks, all 1/2inch tubing, and 6 120mm fans. AMD 4800 @ 2.83ghz, x1900xtx, x1900cf, bfg 1kw psu, asus a8r32mvp, 2gb corsair 3500ll pro, x-fi fatal1ty, (2) 74gb raptor's raid 0, 500gb wd caviar.
With this set up my idle temp on my cpu is 41c and load is about 48c. This doesnt sound right to me. My cards idle at 38c. Right now my cooling loop goes...
Pump>cpu>gpu>gpu>radiator>resevoir>pump
I have no idea what I am doing wrong but I do know that my temps are way off from what I see other people have with a similar set up. A friend of mine has almost the identical setup and his idle is about 33c. The ambient room temperature in my this room is about 75f.
The part of this that is killing me is when I had just that huge zalman copper cpu fan hooked up my idle was 45c and load was 52c. I did not just pay $400 for a 4c drop in load. I am also running fluid xp exreme in my system. Thanks in advance for any help or suggestions.
