I am sorry for the long lines but i wanted to give all the details
Untill 2 days ago I had 2 modules of 512mb of ram from Kingmax(ddr400
@2.5-4-4-8). I bought 2 more modules from Kingston(ddr400@2.5-3-3-8)
because I could not find Kingmax memory . I put the memory in the slots, booted the PC and the memory was recognized fine but when I used Cpu-z and PcWizard2006 to check my memory I saw that the frequency and timings had changed as well as the FSBRAM. I will now explain.
The memory did not worked at 200mhz with 2.5-4-4-8 timings but at160.8mhzwith 2.5-3-3-7 timings.
At first I was thinking that the memory is the culprit but then I tried different settings in the slots and now I think that the motherboard is the problem :idea: . These are the settings that I tried:
1.only the 2 modules from Kingmax worked at 200mhz@2.5-4-4-8
2.only the 2 modules from Kingston worked at 200mhz@2.5-3-3-8
3.one module from Kingmax and one from Kingston worked at200mhz@2.5 -4-4-8
4.the problem was when I put all 4 modules. Memory only worked at160.8
mhz@2.5-3-3-7. I tried all combinations in the memory slots but nothing
5.the "Memory" tab in Cpu-Z shows Fsbram Cpu/12 only with 1gb of ram (from either brand or combined), but with all 4 modules shows Cpu/15
6.I also run a memory benchmark with PcWizard2006 and the memory bandwidht with only 2 modules( from either brand or combined) working at 200mhz@2.5-4-4-8 timings was 6432mb/s but with all 4 modules working at 160.8mhz@2.5-3-3-7 the bandwidht dropped to 5146mb/s
What can I do, because in BIOS there are no available settings for memory excepting those for voltage?
Could the MOBO be broken?
Will a Bios update help?
Is the Mobo unable to handle 2gb of ram because in the manual it states that it can support 4gb of ram ddr400/333/266/200?
Is there any one that has this MOBO and had had a similar problem?
Please help
Thanks
My PC:
MB:GA K8N PRO-SLI revision 1.0, bios version F2
CPU:AMD64skt939 3800+Venice
RAM: 4*512mb ram
VGA: Sapphire x1900gt
HDD: Seagate 80gb sata
PSU:560W Chieftec
Please help
Thanks
My PC:
RAM: 4*512mb ram
PSU:560W Chieftec
