Latest Reviews & Articles
Life At 2 GT/s: 6 GB DDR3-2000 Memory Kits Compared
Memory vendors put a lot of effort into drumming up excitement over high-end memory kits, but many of those products turn out to be vaporware. We test six DDR3-2000 kits that enthusiasts can actually buy today, and push them as far as they'll go. Read more
DDR3 Memory Scaling On AMD's Phenom II X4
DDR3 memory is available in speeds ranging from DDR3-800 to DDR3-2133. Which is the best memory choice for AMD’s Phenom II X4? We tested as many speeds as possible using aggressive and conservative timings to find the sweet spot for your next build. Read more
Intel Core i7-975 Extreme And i7-950 Reviewed
Today Intel launches two high-end processors that take the place of its i7-965 and i7-940 CPUs. More speed? Same price points? We’ll take it! But are the new chips compelling enough to warrant spending more than you would on an i7-920? Read more
AMD Athlon II X2 / Phenom II X2 And Low-Power CPU Bonanza
Eager to let you know it’s been busy, AMD is launching four new processors today: the first Athlon II, a dual-core Phenom II, and two low-power 65W Phenom IIs. We bought ourselves a new Pentium E6300 and let loose with AMD’s latest. Read more
All the Reviews & Articles
Tom's Hardware > Forum > Computer Peripherals > Scanners > HELP: Scanner Microtek Phanton 4800
Archived from groups: alt.comp.periphs.scanner (More info?)
Hello,
I've been using a scanner Microtek Phanton 4800 for 5 years now under
Win98/SE/Me.
I'm connecting it to my PC with a SCSI/USB1 adaptor from Entrega and it has
been working fine. (Connecting it via USB allows me to hot swap the scanner
from from one PC to
another when needed....)
I'v' 3 problems now moving to Win XP Pro SP2:
-I need a driver for XP allowing connection via USB1
-I replcaced the neon light but the power(yellow) and ready(green)
LED/lights are still blinking for long time before stabilizing lighted,
which probably mean the condensator/capacity/starter is bad ... I would like
to change it, but I can't find the place where it is located !!! ?? So, ....
-I would appreciate to get an electronic copy of the ref/tech manual for
this scanner ???
If somebody can help, thanks in advance
Regards
Castor , e-quinqua
enlever le ~ pour utiliser l'adresse email
Sponsored Links
"Castor" <castor2cod1@~hotmail.com> wrote in message
news:41efb4a3$0$1867$626a14ce@news.free.fr...
> Hello,
> Win98/SE/Me.
> has
> scanner from from one PC to
> like
> this scanner ???
> Regards
> Castor , e-quinqua
Seems that that scanner is also a Microtek E3.
There are some manuals also. Put E3 in the box for model name.
http://www.support.microtek.com/
Phantom 4800 / Scanmaker E3
http://www.scanner-drivers.com/drivers/58/58543.htm
You have to register (free).
CSM1
http://www.carlmcmillan.com
Reply to Anonymous
- 0 +
"CSM1" <nomoremail@nomail.com> a écrit dans le message de news:
B5RHd.3982$2e7.1147@newssvr12.news.prodigy.com...
>> Hello,
>> Win98/SE/Me.
>> has
>> like
>> this scanner ???
>> Regards
>> Castor , e-quinqua
> CSM1
Thanks.
I already have this microtek.inf file from this site. It doesn't solve the
connection through SCSI/USB adaptor which was previously running with Win
98SE/Me ...
Regards
Reply to Castor
news:41efe7ee$0$25765$626a14ce@news.free.fr...
>>> Hello,
>>> Win98/SE/Me.
>>> has
>>> like
>>> this scanner ???
>>> Regards
>>> Castor , e-quinqua
>> CSM1
> Thanks.
> the connection through SCSI/USB adaptor which was previously running with
> Win 98SE/Me ...
> Regards
For the scsi card you have to have one that works in Windows XP. Windows XP
will have built-in drivers for some scsi cards. You also have to have ASPI
installed for XP to see scsi scanners.
The ASPI package.
http://www.adaptec.com/worldwide/s [...] PI+Package
Did you check the Microtek site? they have an actual driver and manuals. you
have to look for The Scanmaker E6 scanner.
This is the Scanmaker E6 scanner download for manuals and software.
http://www.support.microtek.com/pr [...] 014&ctgy=7
The driver is ScanWizard version 2.60.
Reply to Anonymous
There are 395 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
