Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > what are good quality fans for a thermaltake case....?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - what are good quality fans for a thermaltake case....?
i have the xaser V with its 3 90mm and 2 80mm fans....
well the fans suck and are starting to bother me with both noise and cooling power....
1 already broke because it clipped a twist tie and snapped a fin...another started humming and i took it out further reducing cooling...
the case itself is awesome...its large has a hardcano monitoring unit for temp and fan speed and has an awesome amount of room for future upgrades...minus its sucky hdd expansion....
i need a good recommendation for quality fans of those sizes
doesnt need lights because i had the solid side...
if they have a fan control on them thats a plus especially if they could plug into a mobo or monitor themselves...
Sponsored Links
Panaflo, vantec Stealth, some1 mentioned these:TT thunderblade
Reply to Anonymous
- 0 +
Uhhh, Thermaltake fans work fine in a Thermaltake case.
My TT Armor has a pair of 90mm's and a pair of 120mm units with blue led's in them..they are quiet and move plenty of air
Reply to mad-dog
There are so many fans out there, and many good companies... depends on what your looking for more, cooling or quietness... if you want power, than Vantec Tornado's for the 80mm... but you definitly need a fan controller if your going for that...
TT makes decent fans, don't really know why you don't like them, the humming might be vibration, check to see if the fans properly mounted and not loose somewhere...
Reply to Doughbuy
There are 1002 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
