Hey,
I have a belkin router and wireless network card...
Is there any reason why when my PC starts up, the computer should have problems connecting? If i click renew.. it works...
It's intermitent... sometimes works fine.. sometimes doesn't..
but only happens on start up.. so theres no problems once its up and running..
It's been happening after I renamed the SSID to something else. I have since turned on the ESSID broadcast after having turned it off to "increase security"... it seems to happen less regularly now..
so anyone had similar problems or know if the ESSID being switched off was the reason?
