I have just installed an Aztech DSL305EW wireless router for my office. The router comes with a 4 ethernet ports.
PCs that are connected directly to the ethernet ports are working fine. All the other notebooks are also able to connect wirelessly (unsecured mode).
When I implemented WEP, the notebooks can get connected but only with 'Limited access'. There are no internet or nework access at all. However, if I manually enter the IP address and DNS, then it worked. Why can't the router's DHCP be able to assign IP addresses to my wireless notebooks only when WEP is implemented?
Also, one of my notebooks faces the same problem even when connected via a Lan cable.
Help!
Help!
