Tom's Hardware > Forum > Computer Peripherals > Scanners > HP 4670 - problems
HP 4670 - problems
Forum Computer Peripherals : Scanners - HP 4670 - problems
Archived from groups: alt.comp.periphs.scanner (More info?)
Does anybody have any problems with this model of the scanner - HP 4670? It
never starts from the first time, I need to plug-off and then plug-in this
scanner to reset it, sometimes it refuses to scan, etc.
I suspect that the default timeouts are not correct and the software doesn't
wait correctly until the scanner initializes, but have no idea how to fix
that. Did anybody see a newer drivers for this model?
Just D.
Sponsored Links
"Just D." <no@spam.please> wrote in message
news:PqzOd.12614$6u.10762@fed1read02...
> It never starts from the first time, I need to plug-off and then plug-in
> this scanner to reset it, sometimes it refuses to scan, etc.
> doesn't wait correctly until the scanner initializes, but have no idea how
> to fix that. Did anybody see a newer drivers for this model?
> Just D.
Link to HP Software & Driver Downloads for 4670 Scanner.
http://h10025.www1.hp.com/ewfrf/wc [...] g=en&cc=us
There is a Check for Updates button on this page.
Also Trobleshooting Software & Driver installation issues.
CSM1
http://www.carlmcmillan.com
Reply to Anonymous
try different usb connections. you may need a powered usb hub. remove all software, download from hp site
col904mu1
col10862
cit 207355-hpcom-patch-v8
I had a usb external drive, scan did not work when it was on, probably irq conflicts
works great now
Reply to Anonymous
Check the dates, this is a 4 year old thread.
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
There are 1154 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
