Tom's Hardware > Forum > Computer Peripherals > Scanners > Scanner Button Will Not Work
Forum Computer Peripherals : Scanners - Scanner Button Will Not Work
Archived from groups: alt.comp.periphs.scanner (More info?)
1. Ensure scanner is on.
2. Go to Control Panel open Scanner and Cameras
3. Click on Devices tab, make sure your Scanner is highlighted, click on
Properties
3. Go to Events tab under Start Button click on programs you want to start
4. To test Scanner go to General tab
5. Utility tab shows Interface used in connection to you Scanner
Sponsored Links
There are 1169 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
