Hi,
My son's computer with the following (main) components,
Motherboard : Gigabyte GA-8GPNXP Duo
CPU : Intel P4 540
Mem : Noname 2x512MB DDR2 667
Graphics : ATI Radeon X850XT PCIe-16
PSU : Thermaltake Toughpower 700W W0106
Hard Drive : 250 GB SATA
DVD-RW : LG
There are a few fans and LEDs as well in a Thermaltake Armour Case
has problems trying to start.
When the front panel power switch is pressed the computer has power for a fraction of a second (all the fans start spining and the lights come on etc.) and then it dies. If the power switch is pressed again nothing happens, i.e., the computer acts like it is completely dead. I disconnected and checked the power cord and its voltage and everything is fine (230 V). After waiting a while and reconnecting the power cord and then pressing the power switch again it tries once again to start but it just can't make it passed the first second. Strangely, once after the above mentioned repeated connecting/disconneting procedures the computer was able to start and everything work as before without problems, 3D games (Battlefield 2, Couterstike Source, etc.) had no problems, i.e., no shut-downs or anything abnormal happend. Unfortunately this has not happened again.
I also tried the screwdriver short of the switch pins and it behaves as described above - tries to start but just can't.
Does anyone have a clue what might be wrong with the computer system? Is it the power supply? Any tests I can do to isolate the problem?
Your help will be greatly appreciated.
Thanks,
George
CPU : Intel P4 540
DVD-RW : LG
Thanks,
George
