This has happen before and it just kind of fixed itself after I let my computer sit for a while but this time I can't get it to work right. Whenever I turn my computer on the videocard does not send any signal to my monitor and the monitor just goes on stand by. On the Video card there is only digital display hook ups so can't really try and hook it up any different way. Just wondering if the card is messed up or if there is some way to fix it.
i'm having the same problem with my p5b deluxe (check mobo forums).
It could be anything man. Not just your vid card. Could be your RAM, power, CPU, virtually anything that is connected to your mobo could make it not boot properly w/o video.
so the best thing to do is open up your computer and check all connections. try to look for places the motherboard might short out such as a screw stuck between the mobo and the case etc.
make sure your vid card is connected to the pcie slot properly (gold flatpin connectors should barely be showing if at all.)
