Tom's Hardware > Forum > Graphic & Displays > ATI > problem with oblivion hdr+aa
hi i have an x1950xtx, and am using the cat 6.10 drivers. i have oblivion set to hdr without anti aliasing, and i have tried in the control center anti aliasing at 2x 4x and 6x, and i still get jaggies. i have everything else set to let the application decide, and catalyst AI disabled. i also have HQAF off and temporal and adaptive anti aliasing off
Sponsored Links
I have a x1900xtx with the 6.10 drivers and I run AA+HDR in Oblivion just fine.
I have AA set to 4X in CCC, everything else is default.
You may not have adequately removed the previous driver before installing 6.10. You really need to remove every last vestige of the old driver, Discard your boot drive and get a new one, reinstall Windows and get a new monitor.
But I'd start with really scrubbing the old driver off. ATi has instructions. Or you could use Driver Cleaner Pro.
Reply to sruane
ive already removed every little bit of every ati driver and installed 6.10, forgot to mention that sorry.
Reply to WhitenameseKid
- 0 +
Reset CCC to the default settings, then just turn on AA at 4X.
Reply to sruane
There are 1301 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
