Archived from groups: (More info?)
I am having a problem file-sharing on a network between computers in my flat
I have set up my Buffalo 802.11g base station and can access the internet
through any computer in the flat fairly easily although the Buffalo signal
report seems to float at will between WEAK and non-existent (disconnecting
relatively often even when I am doing nothing on the computers and not
moving them or anything!). There are a few thin walls and doors and about
35 feet between my living room and office which is where my cable modem,
base station and main computer (hard wired into the router) are. I have
encryption enabled and it seems to work, permitting that living room
computer to access the internet through that Buffalo base station.
I have two problems: One is that my neighbour downstairs seems to have a
linksys base station in his office which is pretty much directly below my
living room pickup. So the computer often turns on to HIS base station
rather than mine. Not such a bad thing as his signal usually shows an 80%
strength reading whereas mine ranges between 25% and 50% (usually in the
lower of that range). And he doesn't seem to have encryption enabled; so I
don't mind piggy-backing off his network if HE is so rich as to have bought
some type of ultra-powerful antenna booster to interfere with my signal. (I
set my channel to 1 whereas his is at 6 to try to obviate this problem with
apparently mininal effect)
The MAIN problem is that I can't get MY computers to file share on my
network together when the living room one is picking up on the Buffalo
network so I can transfer files between the main computer in the office
running windows 2000 and the living room one running XP Pro.
If the living room one does pick up my network and surfs on my network, is
this something to do with the name on the network and is there a way of
renaming a whole network so that all computers on it are the same? I tried
to make them the same and am pretty sure I enabled file sharing between
computers on MY network behind what I presume is my encrypted firewall but
am not sure where to check this or whether I was successful in doing this.
I also haven't figured out yet how to enter the incoming POP and outgoing
SMTP configuration so that it lets me send and receive e-mail when I am
piggy-backing on his network (or for that matter using any WiFi networks on
my main computer which is a notebook outside my office). My network settings
seem to want me to enter these settings (which work well/easily enough when
I am using the Buffalo network through my own base station at home) but I
think this must be an obvious question which must have been answered a
million times already otherwise no one could check or reply to e-mail on the
road?
Does anyone know how I can get file sharing working and point me to the
standard form reply to those who have this 'e-mail while roaming' problem
please?
L2Q
1.- Try placing your router near the strong singnal of you naighbors'. Your
signal will jam your naighbors' singnal for the rest of your house.
2.- Select a channel in your router at least 5 channels away from the
channel of your naighbors'. Let say your neighbor signal is 11 then set
yours channel 6.
Hope this helps, post your results. Good luck.
"Licensed to Quill" <vintagepen@compuserve.nospam.com> wrote in message
news:cj6nu2$mh7$1@ngspool-d02.news.aol.com...
>flat
> bought
> (I
> with
> tried
> on
> settings
> when
> the
> road?
> please?
> L2Q
Hi Dennis
I was hoping I could avoid doing htat as it woudl mean that whereas most
computers all around my house woiuld work properly and my signal from the
base station would overwhelm the neighbour;s signal in MY place, my MAIN
computer in my office woudl then suffer from the lowered signal and would
itself start losing the connection which is the last thing I want!!.
I DID move my channel to 1 as Buffalo told me that it was a stronger
channel than 6 which he uses and it might solve my problem. (But it didnt
really)
The mystery is this business of starting my system to a Buffalo pickup
measuring anything from LOW to EXCELLENT and it then going to NO SIGNAL for
no apparent reason without anyone doing anything or moving anything at all??
(and then offering to switch to the Linksys signal)
L2Q
"Dennis" <sava7@comcast.net> wrote in message
news:E8CdnY5CwrTJU8XcRVn-ug@comcast.com...
Your
> yours channel 6.
> >flat
internet
signal
(disconnecting
about
my
80%
I
> > bought
> > (I
> > with
is
> > tried
but
this.
outgoing
> > on
> > settings
> > when
I
> > the
> > road?
problem
> > please?
> > L2Q
On Tue, 28 Sep 2004 10:45:52 -0400, "Licensed to Quill"
>really)
I once noticed someone waiting in line behind me to get gasoline while
all the other pumps were unoccupied. I couldn't resist and asked why
he didn't just go to one of the other pumps. He replied "Don't you
know that the #1 pump gets the best gasoline?"
If there's any difference in signal level between channels, its a very
small amount. The test results on the FCCID web pile should confirm
that. Actually, channel 6 should give the best performance because
it's away from the effects of filter and antenna tuning effects near
the band edges. Channel 1 tends to have the highest cordless phone
interference. Channel 6 is the default channel for most access points
and therefore is the most likely to collect interference. Channel 11
seems to work the best for me.
If you're getting interference on all channels, there are some
possible causes:
1. Your neighbor has one of those "channel bonded" accellerated
access points that use ALL the channels. If the access point claims
to do 108Mbits/sec, it's one of those. The hog the entire band and
will interfere on any channel. Ask them to disable the turbo, super-g
or whatever it's called function.
2. Your unspecified model Buffalo 802.11g might have the
aformentioned feature. Since you didn't bother to disclose the exact
Buffalo model number, I can't tell from here.
3. You're neighbor might have a frequency hopping spread spectrum
access point instead of the usual direct sequence spread spectrum. If
he has an older access point, it's possible. Look for the names
Raylink, Symbol, Breezecom, or Alvarion.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
I have a Buffalo WBR G54 AirStation which I am trying to use with the
Buffalo PC card which came with it. His signal is not one of those
claiming-108mb (it seems to claim the 2-10 MB P. S. that mine does) and his
system is a NEW one not an older one? More and more puzzling? I will try
to change channels again to 11 but think I had tried this before and
(besides finding that I couldn't easily change the channel on the XP client
computer) still found his signal overwhelming mine (if that is what is going
on) so much as to cause it to disconnect.
"Jeff Liebermann" <jeffl@comix.santa-cruz.ca.us> wrote in message
news:9j3jl0pt0vgqotm8fk9cepn1imgeupuj6a@4ax.com...
> >really)
> possible causes:
Two more thing to try:
1. make sure your are getting full power from your router. It May be
defective and getting less power than you should.
2.-May be your naighbor is using a power amplifier and operating higher than
the legal limit.
My resoning, if you and your naighbor have legal limits, your signal should
should over power his since his router is further away.
news:cjcvlt$p1b$1@ngspool-d02.news.aol.com...
> his
> client
> going
>> >didnt
>> >really)
>> possible causes:
> his
> client
> going
>> >didnt
>> >really)
>> possible causes:
If your PC card or base station accept external antennas, then you can try
using directional antennas. Make sure you have your SSID set to something
different from your neighbors, that will stop it from connecting to the
wrong base station. If you can, max out your signal power settings. You
might also have a non-WiFi interference problem. Microwave ovens and 2.4GHz
cordless phones will cause problems. If your PC card has a setting for
"preferred access point", then set it to connect to your base station first.
Usually you have to enter the preferred AP's MAC address. The Buffalo
equipment may not give you that option.
If you can afford to, switching to 802.11A equipment might be your best
option. 802.11A uses the 5GHz band instead of the more crowded 2.4GHz band.
Distance can be a problem with 802.11A, but if you're only using it in your
apartment then it should work fine. 802.11A will give you the same 54 MBps
bandwidth that the G equipment does. Since G is so much more popular, A
equipment is usually cheaper.
I hope this helps, good luck.
Suggest you also see if your neighbor is using an add-on antenna. that
and/or an amp might be increasing his signal.
Also, are you sure that his signal is blanking out yours - or - is your PC
just connecting with his when stronger. If this is what is happening, you
may need to stop the automatic connection to any AP and only connect to
Preferred APs or even only connect to a specific SSID.
Theoretically, on non overlapping channels (1, 6 and 11) you should be able
to run three networks side by side, one on each channel, and interact with
any of the three.
Bob Alston
bobalston9 AT aol DOT com
"Larry Stroup" <wifiguy2001@yahoo.com> wrote in message
news:Lbp6d.3342$Xd2.2026@trndny01...
>> his
>> try
>> client
>> going
>>> >didnt
>>> >really)
>>> possible causes:
> 2.4GHz cordless phones will cause problems. If your PC card has a setting
> for "preferred access point", then set it to connect to your base station
> first. Usually you have to enter the preferred AP's MAC address. The
> Buffalo equipment may not give you that option.
> band. Distance can be a problem with 802.11A, but if you're only using it
> in your apartment then it should work fine. 802.11A will give you the same
> 54 MBps bandwidth that the G equipment does. Since G is so much more
> popular, A equipment is usually cheaper.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.770 / Virus Database: 517 - Release Date: 9/27/2004
There are 1248 identified and unidentified users. To see the list of identified users, Click here.
