Hello,
My CPU fan just seems way too loud, it's a AMD X2 4200 stock fan. Any suggestions on what to replace it with? It's just really annoying so I don't leave my computer on when I'm not using the computer. I don't OC my system, just need something quieter that's all. I was looking into the Artic Cooling Alpine 64 or Freezer 64 Pro, however I think the pro might just be overkill for what I need.
Any input would be great.
Thanks.
Thanks.
