Help removing shares
Forum Windows XP : Windows XP General Discussion - Help removing shares
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Hello. I used Microsoft Baseline Security Analyzer and it pointed out that I
have shares set up for a few of my folders. (Windows XP Pro with SP2
installed)
So, I went to Control Panel>Administrative Tools>Computer Management>System
Tools>Shared Folders>Shares.
It says I have shares on ADMIN$, C$ and IPC$.
How do I remove these shares? When I doubleclick on the shares, nothing
happens. When I select the share and then go to Action on the toolbar, the
only options are Refresh and Help. Same thing with right clicking on the
share.
Where is the "disable" or "stop" option?
(I have logged in as both administrator and my regular login and both
produce the same results.
Any help appreciated.
John
Sponsored Links
Interestingly, MS says there should be a "Disable" option in the right-click
menu, but it's not present on my computer (XP Pro, SP2) either.
If you use the "Help" option in the r-click menu and look under "Shared
Folders" you'll see how to use Explorer to disable sharing a folder. You'll
also see why this may not be a good idea, depending on what you wish to
accomplish.
> installed)
> share.
> John
Reply to Anonymous
Hi John,
If you have "simple file sharing" turned on, this is normal. It is disabled
under the advanced section on the view tab of Folder Options (WinXP Pro
only, this is not an option on a WinXP Home system).
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"John" <cpocpo@sbcglobal.net> wrote in message
news:OU9a8T$4EHA.1452@TK2MSFTNGP11.phx.gbl...
> I have shares set up for a few of my folders. (Windows XP Pro with SP2
> installed)
> Management>System Tools>Shared Folders>Shares.
> share.
> John
Reply to Anonymous
How to create and delete hidden or administrative shares on client computers
http://support.microsoft.com/?kbid=314984
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Help removing shares
There are 1162 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
