New case, No Post! HELP!!!!
Hello everyone,
Long story short, moved to a Thermaltake Tsunami. Was super careful about everything, but now it wont post.
I have removed all memory, cpu and video card to try to get anything out of it and nothing. I have an Asus P5ND2.
The only thing I did differently was I did not use those cardboard washers between the screw and the MB... Are they needed?
Any suggestions would be greatly appreciated...
JonC
1 answer Last reply
More about case post help
  1. I would recommend using the little washers. Chances are your motherboard is shorting somewhere and you may want to put the washers back on before you damage something (if everything is still ok)
Motherboards Cases Overclocking
