Hi i have the Asus P5W DH intel E6600 and corsair RAM ddr2-800 with 5-5-5-12 timings but I dont really get this part:
so am I really supposed to set it at 533? and not 800? and so Ishould use SPD and not set the timings manualy?
I know its short notice but i could really use some help on this one...
**Expand options for Gigabyte BIOS under ‘M.I.T.’ by pressing CTRL+F1**
Gigabyte: Set ‘Memory Multiplier’ to 2 (1FSB:1RAM operation)
ASUS: Set ‘DRAM Frequency’ to DDR2-533 @266Mhz FSB (1FSB:1RAM operation)
As you increase the FSB, the RAM will follow in the pattern of 1:1 shown in BIOS.
1. Set ‘DRAM Timing’ to manual or disable SPD (use SPD for P5W DH)
2. In BIOS you will see 4 separate timing digits, change them to the ones specified on your RAM
e.g. 4-4-4-12
CAS# Latency (tCL)
RAS# to CAS# Delay (tRCD)
RAS# Precharge (tRP)
RAS# Precharge Delay or Active to Precharge (tRAS)
When 1FSB:1RAM is overclocked above the rated frequency of your RAM use the following values
Timing: 5-5-5-15
vDIMM: 2.2V
e.g. DDR2-667 4-4-4-12 1.9V operating at ~400Mhz will need to be set to 5-5-5-15 2.2V
3. Leave the rest of other timings either at ‘Auto’ or at their default values
