Specs:
ASRock 939Dual-SATA2 Mobo
AMD Athlon 3200+
Corsair Value Select DDR400 2x512MB
evga GeForce 6600
Maxtor Diamond 8 40GB
Problem:
BYOPC has been running for 11 months without problems. Today it stopped booting.
Symptoms:
- On power up, there are no POST messages at all. the video monitor doesn't come out of standby.
- Three lights flash on the keyboard about every 7 seconds
- The CDRom drive seeks every 7 seconds, right before the keyboard lights flash.
- If I remove the memory, the system beeps three times repeatedly (as it should, that's the memory write alarm from AMI bios). This is the only thing I've found so far that alters the boot behavior.
- Disconnecting drives, removing video cards had no impact.
I'm stuck!!! How do I figure out what's wrong? Feels like the MOBO's blown, but is there are way to confirm it other than putting a new one in and seeing what happens?
Anybody seen something like this?
THANKS!!!
schtever
AMD Athlon 3200+
evga GeForce 6600
Problem:
Symptoms:
THANKS!!!
schtever
