Quote:
Well i was just testing out the OCing abilities of my Core 2 e6400 and i was watching the fan speed monitor i have in my motherboards Ocing software and my CPU fan never got above 2000 RPM even though the temps were hitting like 55-58. and i think this is a little low, if some one could help me out with either telling me of a way to manually control the fan speed or a way of telling the Bios to up the speed more.
just so you know i have
e6400,(Was OCd at 2.33 GHZ and running Sandra's CPU burn in software for approx. 20 min straight)
And i have a Gigabyte GA-965P-DS3 running bios rev F7
and this is all cooled by the CPU cooler, 2 80mm fan units, and 1 120 mm fan unit.
THX for any help i get in advance.
First, the stock cooler, unlike what others have said, can run over 4250 rpm, and it makes a bloody racket doing so.
Secondly 2.33 Ghz is hardly much of an an "overclock" of this 2.14 Ghz processor, and shouldn't give more than a temp of 40 or so working hard, on the stock cooler. For 2.33 Ghz the stock cooler is absolutely fine running at 2000 RPM, however your temps are too high so check case ventilation in the area of the CPU and the cooler mounting on the CPU. It can be tricky to get it seated right.
An overclock would be more like 2.6Ghz or greater. My own 6400 runs at 3.2 Ghz, with a max temp of 58 degrees (coretemp, 45 degrees on MB monitoring) using an Arctic Cooler Pro 7.
