I've noticed the BFG water-cooled 8800 GTX's are available with either 1/4 inch fitting or 1/2 inch fittings.
The 1/4 inch card is $899 and the 1/2 inch card is $799. Other than the fitting sizes they seem to be identical.
Why the big price difference and which is better (and why)?
What is the standard Water cooling pipe/fitting size in the USA?
(sorry for the n00b questions, I'm a European just moved to the USA and just getting into Water Cooling).
Thanks guys,
Niz.
** UPDATE: zipzoomfly have added a 3/8" version and made them all the same price. The "which size is best' question still stands though. Which size should I buy and why?
Thanks guys,
Niz.
