Yes, with a good HS you could likely go passive. I was messing around with my P4 2.4A(Prescott) clocked it down to 1.8GHz(18x100) last week, and with an XP-120/sans fan, no intake fans...and only the PSU fan and two rear 80cm(30cfm) fans i ran P95 for ~4 hours. Max temp ~76C. Still, i was suprised that i could run a Prescott(though underclocked) and great HS, passively. Who'da thunk it?Great information, jack and wr - I've been looking for a low power draw, as-silent-as-possible machine with enough jam to still do windows apps (yeah, I know Linux is for low power, blah,blah,blah). The processing power scaling of the C2D Mobile is really evident in those graphs - makes it alot easier to guess-timate what it'll be like at slower speeds - say 1 to 1.4GHz like the AMD Geodes and VIA C7...and those max. load power draw numbers look realistic too. Makes me wonder what they would use with some tweakage and good power management at 1 to 1.4 GHz with under <20% loads? It begins to look possible to make one of these fanless - it'd be a big heatsink, but not immense or unobtainable. Thanks.
If you want the lowest power consumption then you should be looking at a laptop. I have a Core do laptop that idles at ~12W.What other hardware do you have in your machine, Tanker? I'm thinking of running on-board graphics and only a good sound card to keep power and accessory heat down. I'd like eventually to get a capable, completely fanless audio recording box built in the reasonably near future, using external sata disks to facillitate very high fidelity, long duration recordings in as small a footprint as possible. Does this sound feasible/ practical? I'm going to be off the power grid for long periods of time and would like to capture audio with as few breaks as possible in the recordings and preferably without any background noise of the hardware itself, all with low enough power draw to be solar charged, if at all possible.
eVGA 6800GS @429/1150 (fully unlocked),2x512MB OCZ Platinum Rev2, 250GB Hitachi, 80GB WD, cheap 16bit Creative SB,NIC,DVD-RW,CD-RW, Antec TP 480w PSU, In an Antec Plusview 1000AMG(full tower, but doesn't flow well).What other hardware do you have in your machine, Tanker? I'm thinking of running on-board graphics and only a good sound card to keep power and accessory heat down. I'd like eventually to get a capable, completely fanless audio recording box built in the reasonably near future, using external sata disks to facillitate very high fidelity, long duration recordings in as small a footprint as possible. Does this sound feasible/ practical? I'm going to be off the power grid for long periods of time and would like to capture audio with as few breaks as possible in the recordings and preferably without any background noise of the hardware itself, all with low enough power draw to be solar charged, if at all possible.
How much processing power would you need to run say:
Watching/recording TV/satellite programmes,
