Archived from groups: alt.comp.periphs.scanner (More info?)
After downloading Windows XP updates, none of my programs cannot
communicate with my scanner (canon8400f).
Have reinstalled canon software and checked the Control Panel/Scanner and
Cameras/ to find the scanner is installed. The test shows scanner is working
properly. When trying to use Arcsoft Photostudio 5.5 an error message reads:
There is a twain error, maybe the device is not connected. When
reinstalling the software again a message on the sys tray says: Found new
hardware, It is installed and ready for use. Also during the install of
Page Manager (part of the cannon software) two error messages appeared. The
heading is "Severe, creatfile Failed" the other, "Severe, writelane Failed".
The program goes on to be installed. Before the update the whole system was
working perfectly. Thank you, Ron.
"Ron Shepherd" <ron@shep5776.freeserve.co.uk> wrote in message
news4dlvt$3k3$1@newsg2.svr.pol.co.uk...
> working properly. When trying to use Arcsoft Photostudio 5.5 an error
> message reads: There is a twain error, maybe the device is not connected.
> When reinstalling the software again a message on the sys tray says: Found
> new hardware, It is installed and ready for use. Also during the install
> of Page Manager (part of the cannon software) two error messages appeared.
> The heading is "Severe, creatfile Failed" the other, "Severe, writelane
> Failed". The program goes on to be installed. Before the update the whole
> system was working perfectly. Thank you, Ron.
"None cannot" means that the programs CAN communicate. I think you mean
"Programs cannot work".
Reinstall Arcsoft Photostudio 5.5.
One trick in Windows XP SP2 is to open the device manager and delete the USB
Controller and reboot. This makes the OS load the correct USB driver. You
may also have reinstall the scanner driver.
Thank you CSM1 for your reply. I have downloaded the new driver from Canon
and executed it as per their instructions. Have deleted the USB controler
and rebooted, (printer is connected to same controler and is working) and
reinstalled all the canon software. The scanner is communicating with the
computer because when I press the copy button the relative software appears
and then an error message saying - unable to open twain source, please check
connection -. Ron
"CSM1" <nomoremail@nomail.com> wrote in message
news:M7tae.1390$%L1.494@newssvr30.news.prodigy.com...
>> Found new hardware, It is installed and ready for use. Also during the
>> install of Page Manager (part of the cannon software) two error messages
>> appeared. The heading is "Severe, creatfile Failed" the other, "Severe,
>> writelane Failed". The program goes on to be installed. Before the update
>> the whole system was working perfectly. Thank you, Ron.
> USB Controller and reboot. This makes the OS load the correct USB driver.
> You may also have reinstall the scanner driver.
> Windows XP Service Pack 2 changes many things in the OS, TWAIN is really
> effected.
> Get the latest download for the CanonScan 8400F.
> http://consumer.usa.canon.com/ir/c [...] elid=10242 >
> CSM1
> http://www.carlmcmillan.com > --
Rather than pressing the Copy button, try scanning with a Photo editor, such
as Photoshop Elements or Irfanview.
Free Irfanview is a good test and copy software, because it has very good
TWAIN interface and Printer functions. It's not a bad simple photo editor
either.
The four files of interest are in the /Windows folder.
Twain.dll
Twain_32.dll
Twunk_16.exe
Twunk_32.exe
One think you may have to do, is remove SP2 and go to Microsoft Windows
Update and redo SP2.
CSM1
http://www.carlmcmillan.com --
news4fuf8$k0d$1@news8.svr.pol.co.uk...
> appears and then an error message saying - unable to open twain source,
> please check connection -. Ron
>>> and Cameras/ to find the scanner is installed. The test shows scanner is
>>> connected. When reinstalling the software again a message on the sys
>>> tray says: Found new hardware, It is installed and ready for use. Also
>>> during the install of Page Manager (part of the cannon software) two
>>> error messages appeared. The heading is "Severe, creatfile Failed" the
>>> other, "Severe, writelane Failed". The program goes on to be installed.
>>> Before the update the whole system was working perfectly. Thank you,
>>> Ron.
>> effected.
>> http://consumer.usa.canon.com/ir/c [...] elid=10242 >>
>> CSM1
>> http://www.carlmcmillan.com >> --
In article <d4fuf8$k0d$1@news8.svr.pol.co.uk>,
ron@shep5776.freeserve.co.uk says...
> connection -. Ron
> > effected.
> > http://consumer.usa.canon.com/ir/c [...] elid=10242 > >
> > CSM1
> > http://www.carlmcmillan.com > > --
Have you tried changing the compatibility mode - I had an AGFA scanner
one time that after installing XP would not work until I changed the
compatibility mode, I think to WIN 98, but give it a try and see what
happens. Good Luck.
Try a complete uninstall and reinstall and ensure that WIA Services is set
to Manual in Control Panel, Admin Tools, Services.
Twain and WIA don't work too well together and WIA will spring into action
if you connect a device such as a digital camera direct to the PC. If
you're using a Canon scanner, use a card reader to get your digital pictures
to the PC.
Cari
(MS-MVP Printing & Imaging)
Cari, WIA services do not appear in Control Panel, Admin Tools, Services.
Perhapps this may be the problem. When you say a complete uninstall do you
mean windows or the Canon software. I have not done this yet. If you mean
windows, then would that mean a clean install of windows?
"Cari" <Newsgroups1@coribright.com> wrote in message
news:gFRae.12893$lP1.5398@newsread1.news.pas.earthlink.net...
pictures
> to the PC.
> Cari
and
connected.
Found
appeared.
whole
Have downloaded irfanview and got the twain error. Went to the two Microsoft
sights and to be honest didn't understand how to do it. Have removed SP2 and
now running XP SP1. Put the Original XP disk in and did a windows repair.
Still no luck. Thanks for your time on my behalf.
news:l2Oae.10$m85.5@newssvr30.news.prodigy.com...
such
> either.
> Download the plug-ins also, Irfanview needs them to have full function.
> http://www.irfanview.com/ >
> If Irfanview returns a TWAIN error, then your TWAIN interface in Windows
is
> messed up.
> There is a way to fix the TWAIN inface in Windows XP SP2, but it takes
work
> and the original XP CD.
> Microsoft KBs.
> http://support.microsoft.com/kb/q300944/ > http://support.microsoft.com/kb/q300462/ >
> Twain.dll
> Twain_32.dll
> Twunk_16.exe
> Twunk_32.exe
> CSM1
Canon
controler
and
the
is
installed.
> >>> Ron.
the
driver.
really
> >> effected.
http://consumer.usa.canon.com/ir/c [...] categoryid =235&modelid=10242
> >> CSM1
> >> http://www.carlmcmillan.com > >> --
Hmmm, I've seen (very rarely) folks losing their Print Spooler Service but
never the WIA Service.
I was actually referring to the Canon software - and there is an uninstall
untility on their website.... Just ensure the scanner is disconnected from
the PC before running the Canon utility.
I'd certainly try one more uninstall and reinstall of the Canon software
before thinking about a Repair Installation.
Cari
news4jdl1$ira$1@newsg1.svr.pol.co.uk...
>> set
>> action
> pictures
>> to the PC.
>> Cari
> and
> connected.
> Found
>> > install
> appeared.
> whole
This is going to get complicated. I suggest printing this Post.
Start by reading the Help on Expand.
Start>Help and Support.
In the Search box type "expand" no quotes.
Under Suggested Topics, there is one Expand, Click on it and print the
results.
That gives you the command structure for Expand.
Now here is where the work comes in.
Start>Click Run. In the Run text box type: command<Enter> (<Enter> is the
Enter key on your keyboard)
You will have a Command Window on your screen.
Put in your Windows XP installation CD in the CD-ROM drive.
For the following I will assume that your CD drive is D: and your Windows XP
is installed on C:. Please change the drive letters to fit your system.
In the command line window you have on screen.
Create a folder to expand the TWAIN files into. md stands for Make Dir. cd
stands for Change Dir. (They are holdovers from DOS days) Type: means type
the command on the command line in the command window. \ is backslash. _ is
underline. There is a space between each part of the command.
The following line is md<space>\expand<enter>
Type:md \expand<Enter> Creates the folder EXPAND in the root of the XP
drive.
Type:cd \expand<Enter> Changes your current folder to the C:\Expand
folder.
You should have on screen:
C:\EXPAND>
Now extract the four Twain files from the CD.
The first command line for twain.dll is:
C:\EXPAND>expand D:\i386\twain.dl_ C:\expand\twain.dll<Enter>
You will see this message for each file. (Drive letters for your system may
be different. My XP is D: and CD-ROM is H
D:\EXPAND>expand H:\i386\twain.dl_ D:\expand\twain.dll
Microsoft (R) File Expansion Utility Version 5.1.2600.0
Copyright (C) Microsoft Corp 1990-1999. All rights reserved.
Expanding h:\i386\twain.dl_ to d:\expand\twain.dll.
h:\i386\twain.dl_: 36366 bytes expanded to 94784 bytes, 160% increase.
Expand the other three files, one at a time.
C:\EXPAND>expand D:\twain_32.dl_ C:\expand\twain_32.dll<Enter>
C:\EXPAND>expand D:\twunk_16.ex_ C:\expand\twunk_16.exe<Enter>
C:\EXPAND>expand D:\twunk_32.ex_ C:\expand\twunk_32.exe<Enter>
C:\EXPAND>exit<Enter>
The exit command closes the command window.
The four new twain files and now in C:\expand.
With Windows Explorer copy the four files in C:\EXPAND to C:\Windows.
If you get a warning about changing system files continue and overwrite the
files in the Windows folder.
You have now replaced the four TWAIN interface files with the Original
uncorrupted files from the CD.
Reboot and hope that fixes your problem.
If that fixes your Twain problems. Go to Windows Update and reinstall SP2.
If this procedure does not fix the TWAIN problem, the only other cure I
know, is a Clean install of Windows XP. Clean install means reformat the
Windows partition and install Windows XP, Windows Updates and all of your
Programs. Backup your data first!
CSM1
news4je7u$u69$1@newsg4.svr.pol.co.uk...
> Microsoft
> and
> such
>> either.
>> http://www.irfanview.com/ >>
> is
>> messed up.
> work
>> Microsoft KBs.
>> http://support.microsoft.com/kb/q300944/ >> http://support.microsoft.com/kb/q300462/ >>
>> Twain.dll
>> Twain_32.dll
>> Twunk_16.exe
>> Twunk_32.exe
>> One thing you may have to do, is remove SP2 and go to Microsoft Windows
>> CSM1
> Canon
> controler
> and
> the
> is
>> >>> Also
>> >>> the
> installed.
>> >>> Ron.
>> >> mean
> the
> driver.
> really
>> >> effected.
> http://consumer.usa.canon.com/ir/c [...] categoryid > =235&modelid=10242
>> >> CSM1
>> >> http://www.carlmcmillan.com >> >> --
The one thing I forgot to say is you must be logged in XP as administrator.
You cannot make changes to the OS without being administrator.
CSM1
news:N%cbe.322$461.153@newssvr11.news.prodigy.com...
> results.
XP
is
XP
> drive.
> folder.
> C:\EXPAND>
may
> be different. My XP is D: and CD-ROM is H >
the
> CSM1
> > Microsoft
> > and
repair.
> > such
good
editor
> >> either.
> >> http://www.irfanview.com/ > >>
Windows
> > is
> >> messed up.
> > work
> >> Microsoft KBs.
> >> http://support.microsoft.com/kb/q300944/ > >> http://support.microsoft.com/kb/q300462/ > >>
> >> Twain.dll
> >> Twain_32.dll
> >> Twunk_16.exe
> >> Twunk_32.exe
> >> CSM1
> > Canon
> > controler
> > and
> > the
source,
Panel/Scanner
scanner
> > is
error
sys
> >> >>> Also
two
> >> >>> the
> > installed.
you,
> >> >>> Ron.
> >> >> mean
> > the
> > driver.
> > really
> >> >> effected.
http://consumer.usa.canon.com/ir/c [...] categoryid > > =235&modelid=10242
> >> >> CSM1
> >> >> http://www.carlmcmillan.com > >> >> --
It was very interesting completing your instructions, thank you. Renewed the
files but alas it didn't work. After the clean install I shall update to SP2
before installing any software and look hard at any other updates. Thank you
once again.
news:AVobe.1147$461.5@newssvr11.news.prodigy.com...
administrator.
> CSM1
> > results.
the
Windows
> XP
cd
type
> is
the
> XP
> > drive.
C:\Expand
> > folder.
> > C:\EXPAND>
> may
> > be different. My XP is D: and CD-ROM is H > >
> the
SP2.
your
> > CSM1
> > > Microsoft
SP2
> > > and
> repair.
editor,
> > > such
> good
> editor
> > >> either.
function.
> > >> http://www.irfanview.com/ > > >>
> Windows
> > > is
> > >> messed up.
takes
> > > work
> > >> Microsoft KBs.
> > >> http://support.microsoft.com/kb/q300944/ > > >> http://support.microsoft.com/kb/q300462/ > > >>
> > >> Twain.dll
> > >> Twain_32.dll
> > >> Twunk_16.exe
> > >> Twunk_32.exe
Windows
> > >> CSM1
> > >> http://www.carlmcmillan.com > > >> --
from
> > > Canon
> > > controler
working)
> > > and
with
> > > the
> source,
> Panel/Scanner
> scanner
> > > is
> error
> sys
> > >> >>> Also
> two
Failed"
> > >> >>> the
> > > installed.
> you,
> > >> >>> Ron.
> > >> >> mean
delete
> > > the
> > > driver.
> > > really
> > >> >> effected.
http://consumer.usa.canon.com/ir/c [...] categoryid > > > =235&modelid=10242
> > >> >> CSM1
> > >> >> http://www.carlmcmillan.com > > >> >> --
