i have a Asus P5PE-VM motherboard in a coolermaster CM Stacker case (newegg product detail)
i removed the stuff that was in the top bay so that i could use that bay for a drive. problem is that the power and reset buttons were one of the things originally in that bay as you can see from the pics at newegg.
so i was thinking it would be nice to just eliminate the power button and use the power supply switch to turn it on and off. so i tried putting a jumper in the two pins where the power switch lead goes. but when i did that, i turn on the power supply and the system starts to spin up and i get a beep and then it shuts right down.
any idea how i can make this work?
