Okay, I've read some reviews (well, quite a few) and although I may still be completley wrong I've done my best .
I'm looking for a PC to do moderate gaming at ~1280x1024 with a decent amount of eye candy. I also like to do some processor intensive work occainsionally. Now, I would also like to overclock and this is where I'm having my dilemma.
This is what im looking at. Any advice would be appreciated. Oh yeah, i'm only on a budget of ~$1000 AUD
C2D E6300 (or 6400 if budget permits) ~$265
DDR2 1G(2x512M)PC5300 667Mhz RAM CL4-4-4-12 G.Skill $205
Gigabyte GA-965P-D3 P965 PCIE16, DualDDRII SATAII Glan (aparrently they are as good at overclocking as the DS3, but with worse capacitors) $189
Cheap Case$25-30
430W coolermaster extreme power $48
That leaves around 233 for the video card which puts me in the range of the 7600GT or the X1950PRO (if I save some more money )
So, total cost $981 with the 7600GT
OR $1082 with the X1950
OR $1142 with the 1950 and the E6400
Now, which should I go with? Am I on the right track with this or should I change something. I could prolly bring this down with some smart shopping and get a new HDD (oh yeah, I'm using old XP liscence and monitor and keyboard and mouse and optical drives etc). Thanks for any help.
*EDIT* I just realised I specified the DS3 instead of the S3. Fixed now, my bad .
Cheap Case$25-30
