I have a fx 55 3800 + on a msi k8n neo4 motherboard and the thing only clocks out at 1204 mhz..... bad chip er what?
Any advice would be appreciated
thanks ,
Orkin
thanks ,
Orkin
something doesnt sound right here?
After all the AMD fanboys making fun of Intels glued process? Not wise...Maybe he wanted dual core so he glued an FX-55 and a 3800+ together...
I hope he didn't buy it (thinking it's an FX-55) at the previously elevated FX prices...only to find out in CPU-Z that it's a 3800+.Im confuses you say that you have an FX-55 and a +3800? WFT is going on :?
Check the Cool'n'quiet settings, have you tried OC the chip in the past?
Does it restart randomly? Crashes during game play?
Details son, details. Cant help ya If I dont know What you have under that desk of yours, in your little aluminum tower.
List anything thats associated with your FX-55, from hardware specs to Temps.
my guess is that its a 3800+ running under CnQ... cuz 1200 is exactly half of the 3800+'s default speed... Fx-55 runs at 2.6... but, yeah, not sure where the fx-55 comes into play then, TBH
the cpu speed will run at exactly half clock speed when CnQ is enabled (ie X2 4600+ @ 2.4 1.4v will run at 1.2 1.1v when CnQ is on)... however, thats just going by s939... if he has a different socket, s754, or am2... it might possibly be different... the HTT speed however might be what youre referring to though... 1600MHz HTT (800MHz full duplex) and 2000MHz HTT (1.0GHz full duplex)
the cpu multiplier cuts in half, giving you your clock speed... a default multiplier of 10x, under CnQ will then be 5x
not sure what else to tell you... but that is how you arrive at the half clock speed with CnQ
240MHz CPU FSB times 10x cpu multiplier gives you 2400MHz cpu speed
240MHz CPU FSB times 5x cpu multiplier gives you 1200MHz cpu speed
nah, my motherboard was cheap (came as part of a combo with the cpu), so, i dont have the option to change the multiplier manually through the bios
you can however change the multiplier with rightmarks cpu clock utility, from 4x to 10x, including half multipliers too... it has a bunch of speed settings on it... but, for my particular cpu, the top multiplier is 10x
but, when i do overclock... what i was giving examples of, is how it works for my set up
