Tom's Hardware Forums » CPU & Components » Sound Cards » Problem: system no sound , need help
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Problem: system no sound , need help
Profile: newbie
More Information
Ok, i spended few hours and try to fix my sound problem on my asus a7n8x deluxe system, but nothing works and finanlly give up come here for help
I am use to onboard sound deivce not pci card, no front panel sound. what i have done: uninstall the sound drivers, reinstall it after reboot,nosound.
There is no error occur during and instance. no matter what i play is a mp3 file or avi, dvd files, play it from dvd rom or my harddrive, it just no sound comes out .
I am 100% sure that i connected my headphone to the right place, and my headphone is working perfectly. even though i got no sound, but my microphone is working, i chated with someone one the internet, they can hear my voice, but i cann't hear anything.
Furthermore, i did everything in the sound and audio device panel, there just no sound comes out.
anyone can help me and give me an advice?
My system :
mobo:a7n8x deluxe
cpu: amd 3200+
hardrive :40gb WD
video card: agp PNY fx 5200
ram: corair select volume 2x512 mb
help!! thanks :( :(
Related Pr oduct
Profile: stranger
More Information
What OS are you using? I have a similiar sysem I use for testing and it
has both the onboard nVidia sound and a PCI SB Live installed. First thing
I'd check is if the correct driver is installed and the OS has enabled it. Some
times even though you've reinstalled the driver, the OS still won't enable the
device for various reasons, ie. IRQ/DMA conflicts, incorrect permissons in
the registry for the vendor, etc. Here's a simple check to perform: Uninstall
the nVidia drivers, do a system restart. At the POST screen, enter the BIOS
setup and disable the onboard audio. Restart the system and have the OS
boot. Shutdown and again at the POST screen, reenable the onboard audio
in the BIOS. Restart and see if the OS detects the hardware change. If so,
reinstall the drivers. This will tell you whether the OS is seeing the device
properly. If your sound still doesn't work, you may have a bad sound chip,
a broken output connector, etc. The SB Live drivers used to enable digital
output by default and alot folks thought their board was bad until they
unchecked this option... :-) I'm fairly sure the nVidia drivers don't have
this option.
Profile: newbie
More Information
thanks for your advice. My system is windows xp home with sp2. after i did exactly as you told me, the system recognized the new hardware. i following the steps installed the sound drive, reboot, and still no sound. i was wondering that if i have a bad sound chip, but why my microphone still working fine? are these two plugs suppose to belong to the same chip?
another question. if i go get a new PCI sound card, the onboard sound card not going to affect it ,right?
Profile: stranger
More Information
May also want to check speaker config if using a 3 rd. party audio manager , like Realtek audio . Check your Audio I/O.
Try turning off DTS interactive , Dolby Digital live , and such , if those options are available. Just some ideas to check.
Profile: stranger
More Information
Of course you can use a PCI sound card if you have an available slot. Just
disable the onboard audio chip in the BIOS and you should be good to go.
I know this is lame question, but I'm assuming that you've checked the
sound / volume control panel and made sure that the wave output is enabled
and that mute is not enabled? I think you mentioned that you were online
and that someone could hear your microphone but you could not hear them.
What application were you using? I've had problems with Teamspeak in the
past where my microphone was 'dead', but I could hear other folks and
vice versa. This was on an Intel setup running Soundmax. There was a
setting that was always getting changed when I did any video capturing by
that app. I always had to go back into the audio control panel and reset
the default devices for some reason. ...
Add a reply
Google Ads
