I think I have most of the computer picked out, hopefully it will run WoW well especially in Raid/PvP situations, and allow me to use FRAPS with decent FPS.
-----LIAN LI PC-61 USB Black Aluminum ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/CustratingReview.asp?item=N82E16811112025
-----Antec SmartPower 2.0 SP-500 ATX12V 500W Power Supply 115/230 V TUV, UL, CUL, CE, CB, FCC - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16817103937
-----G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Standard System Memory - Retail -210$
http://www.newegg.com/Product/Product.asp?item=N82E16820231098
----- Intel Core 2 Duo E6300 Conroe 1.86GHz 2M sharing L2 Cache LGA 775 Processor - Retail -183$ OR the 6400 depending on funds
http://www.newegg.com/Product/Product.asp?item=N82E16819115005
-----ASUS P5B-E Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard - Retail -153$
http://www.newegg.com/Product/CustratingReview.asp?Item=N82E16813131070
-----SAPPHIRE 100186L Radeon X1950XT 256MB GDDR3 PCI Express x16 HDCP Video Card - Retail -269$
http://www.newegg.com/Product/Product.asp?item=N82E16814102067
OR
-----eVGA 512-P2-N573-AR GeForce 7900GTO 512MB 256-bit GDDR3 PCI Express x16 Video Card - Retail -259$
http://www.newegg.com/Product/Product.asp?Item=N82E16814130065
Which of these two video cards would work best with WoW?
And then just some random hardrive. How do you think that will work out? Will those pieces fit in the case fine? Are those nice choices to get the biggest bang for the buck?
Will that RAM work with that motherboard, and is that a decent choice for a motherboard (I dont know much about them).
Also, I only plan on using one hardrive (no raid), one video card, and one PCI slot. Will that PSU be adequate?
OR
