New installation problems
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I just recently reinstalled Windows XP Professional on top of the Home
Edition. I chose not to format my hard drive. When I finished installing, I
found out that all of my programs' shortcuts had disappeared from the Start
Menu and the Add/Remove Programs was completely empty. My programs are all
still in the same place, except the computer doesnt seem to recognise them.
Can anyone help?
9 answers Last reply
More about installation problems
  1. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    > Can anyone help?
    The method that you used for reinstalling Windows, replaced what was there
    instead of repairing it. You need to rebuild your personal extras
    (shortcuts, preferences, etc) and reinstall your programs. In most cases
    they can be reinstalled to the existing folders.
    Sharon F
    MS-MVP ~ Windows Shell/User
  2. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    >>Can anyone help?
    Similar problem here:
    Installed XP thinking it would delete all that old stuff. Re-installed
    programs show on the start menu and add/del new software. Old programs
    still show on Explorer, along with new, although I cannot access the old.
    What (and how)can I safely delete all entries that do not fit current
    configuration?
    I am still running as administrator only. In Doc & Settings, can I
    delete all users and default user folders? And which is my current
    administrator folder (there are two).
  3. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    > configuration?
    What do you mean by "cannot access the old" - old what? Software? Folders?
    Files? Start Menu items? And along with those answers, we need to know what
    happens when you try.
    I'm not clear on what entries you're referring to - "entries that do not
    fit the current configuration" - so can't answer that without more info on
    what exactly those entries are.
    Do not delete the All Users and Default User folders. They provide
    functions that you may need at some point in time. All Users collects info
    (mostly start menu shortcuts) that applies to all users even if there is
    only one user. Default User is a template account used to create new user
    accounts.
    To find out what your current user folder is: Log on with the account in
    question. Then click Start> Run. Type
    %userprofile%
    into the text box and click OK. Windows Explorer will pop up a folder
    window -- the folder specifically for this account currently logged on. If
    you have the Address bar displayed (View> Toolbars> Address), the path to
    that folder will be apparent.
    Sharon F
  4. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    >>configuration?
    The start menu shows only software loaded after reinstalling XP.
    Explorer shows all previous software as well as newly loaded software.
    Previous software does not respond to left or right clicking, or to any
    "open" or other commands. It does delete. If not deleted, reloading the
    software sees the previous installation, usually with some "software
    already exists" message.
    > accounts.
    There are multiple administrator, all users, and default users folders.
    Some are left over from the previous installation, some are newly
    created. I just have to figure out which are which.
    > %userprofile%
    Did that. I assume it is ok to delete the other (old) administrator in
    explorer?
    m
  5. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    It sounds like you reinstalled XP in a such a way that it replaced only the
    Windows folder (and the Windows registry) and leaving all other files on
    the hard drive in place. In this case, the Windows registry is rebuilt as
    well and it has no knowledge of your previously install applications.
    It's also possible that you performed a "parallel" install - two Windows
    folders on one hard drive. Check carefully to be sure this hasn't happened.
    A repair install on the other hand, incorporates existing user profile,
    registry info, etc. while fixing the Windows setup. It also avoids those
    extra accounts with the .<letters here> appended to their names. For future
    reference:
    How to Perform an In-Place Upgrade (Reinstallation) of Windows XP
    http://support.microsoft.com/default.aspx?scid=kb;EN-US;315341
    NOTE: The above article applies to retail CD or a generic OEM CD. If your
    Windows came preinstalled and your recovery media has been customized by
    the manufacturer, check your system manual for restore/repair options and
    for directions.
    You will want to visit Windows Update site to reapply updates needed by the
    operating system.
    You will also need to reinstall any program that will not run as a stand
    alone application (cannot double click the main *.EXE file to successfully
    launch the program).
    If you run into a program that will not let you reinstall because it
    detects the files for the old install of the program, you should visit the
    tech support pages for that program online for "manual uninstall"
    directions. Then reinstall the program.
    Another useful thing to know as you're cleaning up the current setup, you
    will be denied access to folders and files belonging to the "old you."
    Windows is still protecting those files for that account. You can regain
    access to them by taking ownership:
    HOW TO: Take Ownership of a File or Folder in Windows XP
    http://support.microsoft.com/default.aspx?scid=308421
    One way to figure this out would be using Windows Explorer. Open the
    program with the focus on Documents and Settings. If you do not have the
    tree view (folder structure on left, lists of files and folders on the
    right), add a Folders button to the Standard toolbar. A nice addition
    anyhow as it lets you toggle back and forth between tree view and folder
    view.
    Once you have the two paned view, select "Details" as the View. You should
    now see a column showing the dates for each acount folder. I think you will
    find that All Users.xxxxx has a more recent date than All Users. You can
    safely conclude that the most recent folder is the one created by your most
    recent install of XP.
    If in doubt at all, copy data files out of the accounts before removing
    them. Also you may find that you need to do the "take ownership" steps
    mentioned above to grab the data files and to delete the abandoned account
    folders.
    > explorer?
    Should be ok. May want to take precautions as mentioned above.
    Sharon F
  6. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    This is apparently the case.
    Thanks for the help!
    m
    (snip)
  7. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    You're welcome, Mike.
    Sharon F
  8. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    I deleted all old programs via explorer/delete (just right-clicked and
    deleted, then emptied the trash). This seemed to reduce the space used
    by about half the size of the files (as given by right
    click/properties). But that was quite a bit.
    Tried this, but couldn't make it work. Went through all the motions, but
    in the end the files were still there and inaccessible.
    > view.
    > folders.
    Deleted the administrator and users with old dates through explorer. No
    ill effects, and they're gone now.
    Thanks for yer patience and help.
    m
  9. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    If using XP Home, you need to boot to safe mode to work with the
    permissions of files and folders.
    You're most welcome! Thanks for the update on how everything worked out.
    Sharon F
Microsoft Windows XP
