I have an Arctic Freezer Pro 7 for my P4 640. Usually I idle from 40-45c and I get up to around 60c with a load. This is fine, considering that before I got the cooler, I would get close to 80c while playing F.E.A.R.! Anyway, lately my computer has been idling rather hot. It will idle close to 60c. Thing is, if I start loading, like running prime95 or playing a game, it won't change much... maybe only 4 or 5 degrees. I can reset the computer, and my idle temps are back to normal.
Is this the sign of a problem? Heatsink failing? Inaccurate temp reporting maybe? I'm just using the Asus PC probe that came with the MB. Is there better software for temp monitoring?
Thanks.
Jeff
Thanks.
Jeff
