Hey all...
I pretty much am looking at the same set up as the previous (air cooling) post however I am looking to give the entire system a thorough overclocking.
E6600 or E6700
Asus Striker Extreme 680i
BFG 8800gtx water cooled
So obviously the vga has the blocks...but what blocks will be the best fit for the 680i? Will the blocks used with previous nforce boards fit?
I also would love opinions on water cooling kits that can run the vga, mb and processor. If I need to go custom that is fine but if a prebuilt solution is there which may only require the addition of a block and some extra tubing that is preferable.
Thanks a million!
E6600 or E6700
Thanks a million!
