will quadro work with some of the current motherboards?
Hufen
47
im looking to buy a e6600 and then just upgrade later to a quadro but keep the same motherboard, will the motherboards that support the e6600 also suport the quadro?
thanks, Chris.
zerobeta
25
Just check the specifications of the motherboards
Some board support both core 2 duo and core 2 quadro
Some I think support just core 2 duo
An example, the ASUS P5B and P5W support core 2 duo and quadro as well, so you will be able to upgrade later
