What sound card actually will output 5.1 via optical/coaxial
Last response: in Components
Which cards will actually do this.?
This is so i can link my pc to the main TV amp.
I brought a cheapo 5.1 of ebay, but the optical is only in stereo?
Cheers
Cheers
More about : sound card output optical coaxial
The only way your 5.1 can receive 5.1 audio over coax or optical would be if it were encoded in DTS or Dolby Digital. DVDs have their audio tracks encoded this way but there aren't any sound cards out there that have any real-time encoding built in, as far as I know.
You can output sound in 5.1 from your card using analogue outputs and hooking them up to a 5.1 system meant to accept them, such as 5.1 systems built for PCs.
Your 5.1 digital amp is only receiving a stereo feed as your PC can only put out PCM audio (like a .WAV file or CD audio content) in real time, it's simply too much to ask it to play your game and encode 5.1 channels.
You can still watch your DVDs in true 5.1 using your setup by going into the audio options of whatever software DVD player you use and selecting S/PDIF output.
If you want to play games in 5.1 then I suggest you purchase some 5.1 PC speakers, such as Creative or Logitech produce.
Quote:
The only way your 5.1 can receive 5.1 audio over coax or optical would be if it were encoded in DTS or Dolby Digital. DVDs have their audio tracks encoded this way but there aren't any sound cards out there that have any real-time encoding built in, as far as I know.You can output sound in 5.1 from your card using analogue outputs and hooking them up to a 5.1 system meant to accept them, such as 5.1 systems built for PCs.
Ah ok.. as all this PC is used for is playing movies on the TV (HD/DVD/etc).
So setting the card to output in 2 channel SPDIF is fine, you just send and encoded stream overthis by telling the program to output using SPDIF?
Your sound card needs to support DTS and DD to be able to output 5.1, although most sound-cards support this anwyways. Next, you need a software that supports DTS and DD in order to decode the DVD's or any other codec that supports 5.1 channel sound, PowerDVD and some of the other major DVD players support this.
Then your pretty much good to go, hook it up to your receiver and have fun listening.
Related ressources
- Need a Soundcard with 5.1 Through Optical - Forum
- The only way to get 5.1 audio ? - Forum
- Realtek HD audio, Optical out. Games in 5.1 ? - Forum
- Sorting Through Sound Card Abilities - Forum
- Ideas for updating PC sound system? - Forum
The Auzentech Xplosion 7.1 is an excellent choice. A good second would be the M-Audio Revolution 7.1
Good luck!
Good luck!
Quote:
The Auzentech Xplosion 7.1 is an excellent choice. A good second would be the M-Audio Revolution 7.1Good luck!
The OP said he wanted Optical 5.1 out, i didn't see any optical out on the M-Audio Revolution, an as far as i know the Xplosion 7.1 is the only soundcard out that supports DTS and optical out, not even oh holy (/sarcasm) Creative has an optical card :!:
What you are looking for is called Dolby digital live, like what the Auzentech and my P5W DH have.
http://www.extremeoverclocking.com/reviews/sound/Auzent...
The auzentech is a very nice card, but the op said he already has a card... shrug... so I don't know if he'll get another card.
The Realtek codec's usually support Dolby, but you should always double check:
http://www.realtek.com.tw/products/productsView.aspx?La...
I'm not sure about ADI codecs nor C-media...
Quote:
Which cards will actually do this.?This is so i can link my pc to the main TV amp.
Cheers
Just to emphasize and confirm what one of the above posters said, the Asus P5W DH Deluxe motherboard has a Realtek chip which supports Dolby Digital Live. It encodes your audio on the fly and sends it via optical or via coaxial to your amp, thus enabling you to get the 5.1 sound you so crave. I can also attest that there's absolutely no delay in the sound, at least none that I can sense.
I am using a laptop with digital S/PDIF out. Due to the limited room available for ports, laptop sound solutions generally have dual use ports whereby for example 7.1 sound is output two ways:
Digital - S/PDIF out
Analog - 2 speaker, mike, line in and S/PDIF ports
To use with a digital sound system, such as the Logitech Z-5500 seems problematic as the laptop outputs are 3.5 mm minijack and the speaker inputs are RCA type conenctor.
The only place I found making this cable is:
http://www.ramelectronics.net/html/RCA-mini-spdif.html#...
I had previously hooked up the speakers using the analog outputs / cables and I can say that there is a world of difference between the analog and digital cables. Not only in the sound but also in ergonomics (analog cables plug in to front right side of laptop, winding up under my wrists when hands rest on laptop surface), aesthetics (had to split 3 pair analog cable with 3 strands running along side and 1 to back) and portability (yank 1 plug when elaving ffice instead of 3)
Also check out this
http://us.creative.com/products/product.asp?category=1&...
Also check out this
Quote:
I am using a laptop with digital S/PDIF out. Due to the limited room available for ports, laptop sound solutions generally have dual use ports whereby for example 7.1 sound is output two ways:Digital - S/PDIF out
Also check out this
Cheers guys for all the help..
Quote:
Your sound card needs to support DTS and DD to be able to output 5.1, although most sound-cards support this anwyways. Next, you need a software that supports DTS and DD in order to decode the DVD's or any other codec that supports 5.1 channel sound, PowerDVD and some of the other major DVD players support this.Then your pretty much good to go, hook it up to your receiver and have fun listening.
If you have an external dts decoder, your card can just be set to spdif. That's what i do with my Audigy 2 zs + Logitech Z-5500. The Z-5500 hardware does the actual decoding of the dts stream.
I'm currently listening to the new evanescence opendoor album on 5.1 dts, it's great. Although i'm having a hard time trying to get linux[alsa] to output using spdif. Windows + Winamp + winampac3 plugin work fine though with spdif.
Icy18, you're killing me...the OP asked for 5.1 optical or coax cards...read the subject line!
yeah, the only sound cards that offer realtime digital 5.1 encoding in either ddl or ddl/dts are:
Turtle Beach Montego DDL - Offers only DD live, and only optical toslink digital connections
HDA Blue Gears X-Mystique - Offers only DD live, offers both coaxial rca and optical toslink digital connections
HDA Auzentech X-Plosion - Offers both DD live and DTS interactive, offers both coaxial rca and optical toslink digital connections
HDA Auzentech X-Meridian - Offers both DD live and DTS interactive, offers both coaxial rca and optical toslink digital connections
Creative also offers an external DTS interactive interconnect, called the DTS-610... its certainly not efficient when it comes to cable usage, but it gets around the DRM issues
Quote:
How does PS2 have optical out 5.1 during gaming?a PS2 doesnt output 5.1 surround when gaming, that only happens during movie sequences (which are sometimes pre-encoded in a surround format already, usually dolby digital if anything)... ...during actual gameplay however, youre limited to strictly 2 channel PCM... lame, i know.
an xbox however, does offer 5.1 surround when gaming, using DD live.
Original Opening Post: I need a sound card that plays movies on the TV. (real answer: any 5.1 soundcard, with SPDIF out enabled).
Response: Buy a pricey sound card that encodes discrete GAME audio to Dolby Digital in real time.
Ahh...well, I guess it's time for our friend "Joe" to start gaming a lot in order to take advantage of his new pricey purchase. Lol.
Hello,
I have a similar question. I connect my logitechZ5500 to my HTPC using the SPDIF output on the motherboard -ASUS P4C800-E. No sound card, I just use what's on board.
Am I missing out? do my 5.1 DVDs get reproduced faithfully (they sound great) and will the Z5500 upmix my stereo MP3s into 5.1? ....OR....
Will a SPDIF O/P from the m/b only carry stereo sound? meaning I have to purchase a card that a) sends 5.1 over SPDIF for my DVDs and b) upmixes mp3s into 5.1, sends this over the SPDIF and allows my Z5500 to decode them?
I only use it for movies and music....So the question is - will a new sound card be of use, or am I hearing true 5.1?
thanks
tom
thanks
tom
Related ressources:
- ForumHow to connet by PC sound out put (8channel) to HDTV via a 3.5mm o/l with out l
- ForumOptical in sound card with 5 1 support
- ForumNo True 5.1 for Gaming, is this right? HELP!
- ForumPC Surround Sound Home Entertainment System !
- Forummutiple 5.1 outputs? :-)
- Forum5.1 wont play through optical SPDIF output
- ForumPc sound card directly (w/out reciever) to 5.1 HT speaker system
- Forumlogitech z5500 vs creative gigaworks s750
- ForumBest sound card for headphones and 5.1 surround gaming
- ForumFour MicroATX Mobos for Core 2
- Forum212 evo fan replacement
- More resources
Read discussions in other Components categories
