Case designs with bottom mounted power supplies
Last response: in Components
I’m researching what pieces to buy for my first build. For a power supply I was considering a Thermaltake 700w W0106RU or 750w W0116RU. The fan of these power supplies is located at the bottom.
Now some cases like the Antec Nine Hundred mount the power supply at the bottom of the case. So my question is, I could NOT mix these power supplies with case designs that mount them at the bottom because it would block the fan??
More about : case designs bottom mounted power supplies
Thanks for replying. I am a little confused now. In this post here
http://forumz.tomshardware.com/hardware/FULL-ATX-GAMING-TJ09-leadingftopic-207017-days0-orderasc-25.html
it is not recommended to turn the power supply upside down.
Quote:
I’m researching what pieces to buy for my first build. For a power supply I was considering a Thermaltake 700w W0106RU or 750w W0116RU. The fan of these power supplies is located at the bottom. Now some cases like the Antec Nine Hundred mount the power supply at the bottom of the case. So my question is, I could NOT mix these power supplies with case designs that mount them at the bottom because it would block the fan??
The Cooler Master STackers ( I think all of them, but I know my STC-T01-Original stacker) has a mesh on the bottom.
I have my Antec TP-II 550watt that has a 120mm fan sitting on top of the mesh. With the caster-wheels on the case it sits up about 2 inches off my carpet and sucks air from outside the case off the floor, where it is nice and cool, into the psu box and out the back of the case.
You can mount the psu up top or on the bottom or mount 2 psu's if you need that much power (and who's kidding who, with the latest trend of video cards you'll need 2 550's or 1 giant 1000 to run it all by this time next year - quad core and dual or quad video, lol power hungry indeed).
I love my stacker case, but it is HUGE. About the only thing I don't like about it is that the top exhaust blow hole is an 80mm where the Antec900 is something like 160mm.....I'm trying to decide how important it is for me to have that....ie do I really want to cut a hole or not
Related ressources
- Bottom Mounted Power Supplies ? - Forum
- Bottom Mounted PSU, fan facing Up or Down? - Forum
- Bottom mounted PSU - fan facing up or down, a test - Forum
- Question on Bottom Mounted PSU's - Forum
- Bottom mounted PSU advantages and 4Gb vs 8Gb of ram - Forum
ahhhh... that...
http://www.tweaknews.net/reviews/antecninehundred/index...
They mounted it upside down... I really don't think you should worry about it, but if you really want to know, email Antec and TT and see what they say.
Uh... I'd be very concerned if you had loose screws or wire's running amok in your case... cable management solves a lot, and being careful takes care of the rest. There might be a slight chance that happens, but then you can take it as a learning lesson...
Although, the whole purpose of a bottom mounted PSU bay is so the PSU doesn't pull up the hot air from the CPU and so it can run relatively cooler...
I just built an antec 900 yesterday, and there is NOT ENOUGH room to mount such a PSU normally, it HAS to be upside down. That being said it shouldn't hurt to mount the PSU upside-down, but keep in mind that it will be venting warm air UP, so you'll want to blow that air out of your case, but that's all. Just reverse that monster top fan and you'll be golden.
Quote:
I just built an antec 900 yesterday, and there is NOT ENOUGH room to mount such a PSU normally, it HAS to be upside down. That being said it shouldn't hurt to mount the PSU upside-down, but keep in mind that it will be venting warm air UP, so you'll want to blow that air out of your case, but that's all. Just reverse that monster top fan and you'll be golden.So what PSU did you use for your build with the _900? I am planning on the Tt 650w truepower. Is there a concern about the cables/wires being too short when PSUs are bottom mounted ?
It was a Gigabyte DS3, and yea, the 4-pin is up above the socket on that one. Further complicating matters, the customer had me put a Big Typhoon on his CPU, and without thinking I attached it before I plugged in the 4-pin. Luckily I have nimble fingers....hahaha. I really like the 900 case though, it looks sharp. The Drive cage could be moved up, with some difficulty though, cuz of the fan that's semi-attached. But the molexs on the OCZ are more than long enough to reach the top, it was only the 4-pin that cut it kinda close...
Quote:
I used a OCZ GameXStream 700W. Cable length could be a problem, the only cable I had to worry about was the +12V 4 pin, it just barely reached. Also, traditional molexs might be a problem if the wires are too short, as optical drive mounting is only available up at the top of the case.No problem moving them - I have my optical drives and floppy at the bottom, HDD's in the middle and top bays empty, so I have a fan blowing towards my gfx card over the HDDs and the other fan towards my FreezerPro. With the current ambient temp being cool it's at 18' idle and 36' loaded ('C core temp).
I love my 900!
I recently built a system with the 900 and a Thermaltake Toughpower 700 and installed the PSU with the fan facing up. When I applied power the PSU's fan rubbed against something internally. It stopped rubbing as soon as I turned the PSU over. The review on TweakNews listed above noted the use of a Thermaltake Toughpower 600 and no mention of fan rubbing. I wonder if the one I got just has a loose fan. Could also mean that PSU isn't designed to run while upside down. I sent an e-mail to Thermaltake to ask their opinion.
The 900 case I bought has four silicone pads on the interior floor where the PSU sits. This would only give maybe 1 or 2 mm of clearance if you wanted to mount the PSU with the fan facing downward. The manual says the case has screw holes for mounting the PSU with the fan up or down--either way. I'm doubt that would make the PSU sit any higher when mounted with the fan facing down.
I'm not sure I like the idea of having the fan on the bottom. It might not get enough air, although what it did pull in would certainly be cooler air. With the 120 mm fan on the bottom front of the case, it could conceivably get enough air, but the unused cables also sit bundled right in front on the case.
If anybody has a similar setup with this case with the PSU fan facing downward and gets decent airflow, I'd like to hear about it.
My setup:
--Antec Nine Hundred case
--Thermaltake Toughpower 700W
--EVGA nForce 680i motherboard
--Intel Core 2 Duo E6600 (2 x 2.4 GHz)
--2 GB Corsair XMSExtreme EPP DDR2-800
--ATI X1950 XTX (single card)
--SoundBlaster X-Fi Fatal1ty FPS
--Seagate 7200.10 320 GB SATA II
DigitalKnight
Related ressources:
- ForumDisadvantages of Bottom-Mounted PSU?
- ForumPSU mounted face down fan covered on bottom
- ForumBottom mounted PSU will it cause problems for the GPU?
- ForumComputer Cases power supply Mounted on Bottom
- ForumPower supply exhaust fan direction in top mounted cases.
- ForumPower supply fan facing bottom of case .
- ForumBottom Mount VS Top Mount
- ForumPsu ( bottom mount ) fan direction
- Forum212 evo fan replacement
- ForumTT ARMOR VA8003SWA Case. Is it noisy?
- ForumNeed some help with a PSU
- Forumsomthing wrong with new ati drivers
- ForumCheap case
- ForumLies, Damn Lies, and Power Supplies...
- ForumStock PSU's from good Case companies?
- More resources
Read discussions in other Components categories
